-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   infinity box smart card driver not showing (http://forum.gsmhosting.com/vbb/f296/infinity-box-smart-card-driver-not-showing-2154823/)
mintu4200 11-12-2016 09:53
dear infinity team please solve my problem box take only port n serial bus driver its are not showing smart card driver and box not found smart card driverhttp://i66.tinypic.com/b902c.jpg
YellowBoss 11-12-2016 11:18
Hello,
- Run DongleManager
- Read Box/Dongle serial number (S/N)
DongleManager - http://www.infinity-box.com/support/?r=5
Send us text.
DO NOT send screenshot/video but copy/paste text from software window !
mintu4200 11-14-2016 08:36
not done
Originally Posted by YellowBoss (Post 12155402)
Hello,
- Run DongleManager
Send us text.
DongleManager [Infinity-Box] v1.67 [14-11-2016 13:00:51]
PC HWID: FF2F050EDF959F67CA988456D020293C
Scanning...
Dongle can't be found:
Card with specified AID is not found
dear infinity team this is the error for infinity box when i m trying to update from dongle manager because box not taking samrt card driver and not showing also in device manager........what is the problem can u explain me .....it shows only smart card not found
mintu4200 11-14-2016 08:52
Box/Dongle type selected: Main Infinity-Box/Dongle
---------- Process started: 14-11-2016 13:15:31 ----------
DongleManager [Infinity-Box] v1.67 [14-11-2016 13:15:31]
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 000138BB00001942
Type: Main Infinity-Box/Dongle S/N: -------- Version:
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to http://www.infinity-box.com/support/?r=2
dear team when i opened infinity box n remove n plug in smart card ....then after doing that it gives me that error on dongle manager...please help
InfinityHelp 11-14-2016 20:26
Hello,
- Run DongleManager
- Update Dongle firmware now ONLY ONE TIME
- DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries
- DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle !
mintu4200 11-16-2016 08:25
Originally Posted by InfinityHelp (Post 12159728)
Hello,
- Run DongleManager
this is not proper ur support ...can u explain what should i do instead of update dongle firmware because i tried it many time but when smart card not showing in pc then how can i update it.....
mintu4200 11-17-2016 19:23
What happened infinity team where are you.... I am waiting for ur support.....
Sent from my Redmi Note 3 using Tapatalk
YellowBoss 11-17-2016 21:05
this is not proper your answer
can u explain how can you read dongle details with dongle manager if dongle not detected by pc ?
did you possted fake log text or what ?
did you tried update dongle as per instruction given to you days ago ?
Togbe Djakpata 11-17-2016 21:59
i am facing a similar issue. please help
YellowBoss 11-17-2016 22:28
could you please explain your similar issue in details.
Thank you !
haseebkakar 11-18-2016 03:20
Thank you !
Old Shell v 2.20 no issue more.......card automatic find v v1.58 ok
Togbe Djakpata 11-18-2016 04:01
Thank you !
Please a have posted my version of my problem. I must add that i am having the same issue that Safyan Sufi is having and i have also tried all the things that he has done to solve the problem but non is working.
When i tried to upgrade the smart card in another smart cad reader, i keep getting 'transmit error'
mintu4200 11-18-2016 08:31
HELLO,
Now can u telll me is it hardware issue or smart card error.......if u
mintu4200 11-18-2016 10:33
Problem solve
DEAR INFINITY TEAM,
I HAD problem with my old infinity box now I Solved my problem my self.....n without any ur support
Here are some screen shots....n method For other users whom face that problem
First a fall remove ur smart card from old box or dongle
http://i68.tinypic.com/2afg4qp.jpg
and put in another dongle type of nokia best
After that if it will show u smart card drivers in device manager then start latest dongle manager setup
after run dongle manager it will be update ur smart card like that sreenshotshttp://i63.tinypic.com/wspvuu.jpg
AFTER updating smart card u can remove ur smart card from dongle n put in ur old box or dongle n now ur infinity cm2 ready for use with ur old box or dongle
http://i64.tinypic.com/amdwgl.jpg
HERE IS SCREENSHOTS OF MY OLD BOX N NOKIA BEST DONGLE WHICH THRU I UPDATED MY INFINITY SMART CARD CARDhttp://i67.tinypic.com/2hyb12r.jpg
YellowBoss 11-18-2016 22:15
Dear Sir,
Could you please explain your similar issue in details, write all your steps, post log text etc.
Thank you !
Page generated in 0.28692 seconds with 5 queries
