11-12-2016, 09:53 | #1 (permalink) |
Freak Poster Join Date: Feb 2014 Location: indore
Member: 2120393 Status: Offline Thanks Meter: 238 | infinity box smart card driver not showing |
11-12-2016, 11:18 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, - Run DongleManager - Read Box/Dongle serial number (S/N) DongleManager - http://www.infinity-box.com/support/?r=5 Send us text. DO NOT send screenshot/video but copy/paste text from software window ! |
11-14-2016, 08:36 | #3 (permalink) | |
Member: 2120393 Status: Offline Thanks Meter: 238 | not done Quote:
PC HWID: FF2F050EDF959F67CA988456D020293C Scanning... Dongle can't be found: Card with specified AID is not found dear infinity team this is the error for infinity box when i m trying to update from dongle manager because box not taking samrt card driver and not showing also in device manager........what is the problem can u explain me .....it shows only smart card not found | |
11-14-2016, 08:52 | #4 (permalink) |
Member: 2120393 Status: Offline Thanks Meter: 238 | Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 14-11-2016 13:15:31 ---------- DongleManager [Infinity-Box] v1.67 [14-11-2016 13:15:31] PC HWID: FF2F050EDF959F67CA988456D020293C Card-Reader: Gemalto e-gate Smart Card 0 HWID: 000138BB00001942 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 dear team when i opened infinity box n remove n plug in smart card ....then after doing that it gives me that error on dongle manager...please help |
11-14-2016, 20:26 | #5 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
- Run DongleManager - Update Dongle firmware now ONLY ONE TIME - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
11-16-2016, 08:25 | #6 (permalink) | |
Member: 2120393 Status: Offline Thanks Meter: 238 | Quote:
11-17-2016, 21:05 | #8 (permalink) | |
can u explain how can you read dongle details with dongle manager if dongle not detected by pc ? did you possted fake log text or what ? did you tried update dongle as per instruction given to you days ago ? | |
11-18-2016, 04:01 | #12 (permalink) | |
Insane Poster Join Date: Aug 2014
Member: 2240998 Status: Offline Thanks Meter: 27 | Quote:
Please a have posted my version of my problem. I must add that i am having the same issue that Safyan Sufi is having and i have also tried all the things that he has done to solve the problem but non is working. When i tried to upgrade the smart card in another smart cad reader, i keep getting 'transmit error' | |
11-18-2016, 08:31 | #13 (permalink) | |
Now can u telll me is it hardware issue or smart card error.......if u | |
11-18-2016, 10:33 | #14 (permalink) |
Member: 2120393 Status: Offline Thanks Meter: 238 | Problem solve DEAR INFINITY TEAM, I HAD problem with my old infinity box now I Solved my problem my self.....n without any ur support Here are some screen shots....n method For other users whom face that problem First a fall remove ur smart card from old box or dongle and put in another dongle type of nokia best After that if it will show u smart card drivers in device manager then start latest dongle manager setup after run dongle manager it will be update ur smart card like that sreenshots AFTER updating smart card u can remove ur smart card from dongle n put in ur old box or dongle n now ur infinity cm2 ready for use with ur old box or dongle HERE IS SCREENSHOTS OF MY OLD BOX N NOKIA BEST DONGLE WHICH THRU I UPDATED MY INFINITY SMART CARD CARD |
11-18-2016, 22:15 | #15 (permalink) | |
Could you please explain your similar issue in details, write all your steps, post log text etc. Thank you ! | |
