05-23-2010, 20:42 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: ! Age: 39
Member: 414755 Status: Offline Sonork: quickgsm Thanks Meter: 389 | Infinity-Box team !!!!!!! big big big thanks for all your team InfinitySupport, Infinity-Box, InfinityHelp, YellowBoss my log Dongle Manager [Infinity Box] v1.32 ----------Process started: 20:07:28---------- DongleManager version: 1.32 Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: 034XXXXX, Firmware: 0112.02 Authenticating on server... Authentication successfull Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Dongle Identification checked Service stage 1 confirmed. Securing session... Session secured ok Upgrading dongle... Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed ----------Process finished: 20:08:07---------- after COM4 [VCP3] selected module v3.26 Device: Alcatel-505X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B94D:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.ED3F4 B70.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_5434F94E].rpl rom info detection finished device-id: ED3F4B70 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 4EF93454 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XP26CQ22 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35777003035207 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_ED3F4B70_5434F94E_20100523-202811.B0X.bin Finished, time used: 3 min 1 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! BR / TA@UFIK BY / QUICK-MOBILE |
The Following User Says Thank You to quickgsm For This Useful Post: |
i WANT TO BUY NOKIA BOX !!! | Eric | Wanted Products | 8 | 02-14-2011 13:23 |
NOKEY BOX FOR SALE - FULL | Zorz | Main Sales Section | 0 | 12-05-2000 10:56 |
New NOKIA BOX - New Prices | gsmEsteve | Main Sales Section | 0 | 12-03-2000 03:43 |
New Nokia BOX for you!!! | gsmEsteve | Main Sales Section | 0 | 11-18-2000 17:09 |
