12-03-2015, 12:28 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Would be great to check that issue, if you can make whole flash dump and send me for check. Yes, it big and hard to upload, but without it can't improve that. |
12-03-2015, 12:30 | #3 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Heart of Asia
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | Sorry but the customer took the phone , If I could find another phone with such problems, I will Sent from my iPhone using Tapatalk |
12-03-2015, 12:46 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Yes, that will be great. Will add option in setting for use "old" read mode, if need. It more universal, but long. Can take up to 5 minutes on 64GiB phones. This one - 20 seconds. |
12-03-2015, 19:12 | #5 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | My Dear Best Friend, I'm Also Facing Same Problem. Operation : Check / Read Info [ v1.38 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001DB90D0F57115 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001DB90D0F57115 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : A60 ProdModel : Karbonn A60 Device : A60 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : UTLA60v1009_05-12-2014 MODEM : BaseBand : MT6572_S00_SM618_GSM4_W1258_MP_V0_0_2_S1020_1_wg_n EXTRA : LCD [0] : hx8379c_wvga_ips_auo5p0_618_qy LCD Res : 0x0 TOUCH [0] : focaltech CAM [0] : gc2145_yuv CAM [1] : gc2145mipi_yuv CAM [2] : ov2685_mipi_yuv MODEM : SM618_GSM4_W1258 LOCALE : en_US es_ES ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG hi_IN ja_JP th_TH kk_KZ pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB fa_IR Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.38 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001DB90D0F57115 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001DB90D0F57115 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Operation : Read PatternLock [ v1.37 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001DB90D0F57115 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001DB90D0F57115 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1599 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 35789 Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
12-04-2015, 01:37 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Read my previous post, please. If you want and can help - there is explained, what need. When someone help me with file - it will be fixed at same day. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
06-11-2017, 03:50 | #7 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2725936 Status: Offline Thanks Meter: 0 | CM2MTK v1.38 boot eror when i read pattern lock I want to read pattern lock on my samsung galaxy note 2 n oppo f1s, but everytime i connect the phone, boot eror, can someone help me what to do Card found : S/N : 740E707F , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:37 Reconnect Power/Cable! |
