01-12-2009, 16:50 | #1 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 528990 Status: Offline Thanks Meter: 12 | infinity cable anyone can help me to repair or to modified of this, pls.. i been try to change the connector but still. only these cable not working.. pls help mga bosing tanx |
The Following User Says Thank You to KARK_07 For This Useful Post: |
02-28-2009, 08:20 | #4 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
http://forum.gsmhosting.com/vbb/show...77&postcount=2 | |
02-28-2009, 13:28 | #5 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Brazil Age: 41
Member: 131402 Status: Offline Thanks Meter: 20 | 1- The box is conected directly to PC USB port, don't use any kind of USB-hubs 2- The “Power” wires connected correctly 3- The connector is completely inserted 4- The contacts is clean 5- The buttom not is demaged (the phone is new) 6- In PCB not have TX and RX printed 7- The connector contacts not cutted internally 8- The phone not have TX and RX 9- the cable not have wire in pin 9 of conector for cut according to picture witch other cables the pinou is are found normally |
02-28-2009, 13:42 | #6 (permalink) | |
02-28-2009, 19:27 | #9 (permalink) |
Member: 131402 Status: Offline Thanks Meter: 20 | hello Mr. InfinitySupport I open the phone and do not have Tx/Rx points. In other models I found the local form indicating the Tx and Tx, but few that have this indication |
02-28-2009, 19:44 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If pinout for 5-pin connector can not be found automatically you can check where is GnD and CHARGE pins at phone connector (ordinary it's pin-1 and pin-5) and you can try to use rest three pins as Rx/Tx. |
New Products: Bird D736 Infinity Cable, LG KE500 Vygis Cable for flash | Tele-way | Main Sales Section | 0 | 10-20-2007 07:03 |
New cables:Motorola F3 Infinity cable/Unibox cable and Samsung C140 Ns Pro cable | Tele-way | Main Sales Section | 0 | 04-16-2007 14:54 |
Convertinmg FLY data cable to infinity cable | apurvag | Infinity-Box | 8 | 03-16-2007 15:01 |
Philips P760 Infinity Cable (Philips update??) | 07heaven | Infinity-Box | 1 | 05-19-2006 13:39 |
infinity cables | MPhoneClinic | Infinity-Box | 8 | 04-04-2006 13:31 |
