infinity can do easly guys infinity do easly ever job . COM3 [VCP0] selected module v2.64 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:3B7C:6E67 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: F:\infinity box\InfinityBox\ChineseMiracle\backup_security\id. FC236848.[CKT26_06B_YR_01_3B_PCB01_GPRS_MT6226_S01.LION6_01_ 26B_YR_L7EN_231_071115_LD-TR0_OV0_SS75_CTF_BT.BIN_96A770FC].rpl identification#1 detection finished device-id: FC236848 identification#1 protocol ver: 04 ver. sw1: CKT26_06B_YR_01_3B_PCB01_GPRS_MT6226_S01.LION6_01_ 26B_YR_L7EN_231_071115_LD-TR0_OV0_SS75_CTF_BT.BIN ver. sw2: LION6_01_26B_YR_L7EN_231_071115_LD-TR0_OV0_SS75_CTF_BT, 038F5869 ffs offset/size: 00F00000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: EC257E25082501:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:2CEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:2CEA0000000000 Finalization Done file saved: F:\infinity box\InfinityBox\ChineseMiracle\backup_security\sys tem_log_FC236848_CKT26_06B_YR_01_3B_PCB01_GPRS_MT6 226_S01.LION6_01_26B_YR_L7EN_231_071115_LD-TR0_OV0_SS75_CTF_BT.BIN_96A770FC_20081015-082022.B0X.bin Finished, time used: 162 sec Remove/Install battery now ! thanks infinity team |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
