11-11-2009, 17:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | Problems with Skyzen EZ200 COM6 [VCP3] selected module v2.92 Device: Skyzen-EZ200 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6218:8B04]... CPU: MT6218 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs address can not be detected, value from database assigned: 00E00000/00200000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Skyzen-EZ200__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Skyzen-EZ200__ffs_20091110-201756.B0E.bin flash: 01227E22212200:29EA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done Write ... flash: 01227E22212200:29EA0000000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 112 sec Remove/Install battery now ! COM6 [VCP4] selected module v2.92 Action: read codes unlock method: read codes Model: Skyzen-EZ200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6218:8B04]... CPU: MT6218 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6218B,E04 Date: 2003.12.29 Version: 1.0 Version: M701.W01.01 Version: M701_HW 73 byte(s) read imei: 35735400046882 connection Ok 78 byte(s) read 156 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 9 sec Remove/Install battery now ! Any idea? |
11-11-2009, 19:44 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It may be problem with new/unknown firmware version. Please, read full flash from this phone and send to support@infinity-box biz so we will be able to check it. |
11-14-2009, 20:39 | #4 (permalink) |
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks Meter: 436 | A promise is a debt. Here the full flash of cell http://rapidshare.com/files/30704563...6.B0X.bin.html |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
problem with nokia 6234 | pachicoo | Universalbox | 2 | 03-29-2010 15:19 |
SkyZen EZ200...! | SSAC70 | Infinity-Box | 13 | 04-08-2009 08:34 |
29 Mar 2008: SkyZen-EZ200, Avvio-G200, Dirland-X410, Fly-Hi-SLDR supported | InfinitySupport | Infinity-Box | 19 | 08-27-2008 12:12 |
