06-24-2014, 07:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: budaun Age: 38
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | infinity box china tool best 1000000% InfinityBox_install_CM2MTK_v0.03 InfinityBox_install_CM2RDA_v0.07 InfinityBox_install_CM2SPD_v0.07 best china mobile tool thx infinity |
06-24-2014, 07:55 | #4 (permalink) |
No Life Poster Join Date: Feb 2012 Location: india (rajasthan) Age: 32
Member: 1719279 Status: Offline Thanks Meter: 140 | yes sure 1000000%% best for china mobile most powerfull and fast repair method with infinity box .& 100%% safe repair set with infinity box . |
06-24-2014, 09:03 | #5 (permalink) |
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | karbonn k phone 1 new1 Card found: S/N 085E:0118 Chinese Miracle II [MTK module] v 0.03 Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 74 ] Sync... Initial Boot Failed (Sync Error) Boot Error! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 74 ] Sync... Initial Boot Failed (Sync Error) Boot Error! Elapsed: 00:00:00 Reconnect Power/Cable! Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 74 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EA0093A7E2E40598A4428341DE5C32CD BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x00000000 , 0x00000000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x00700000-0x007FFFFF , LEN : 0x00100000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:16 Reconnect Power/Cable! Load File File_Info : VSUN60A_11B_PCB01_gprs_MT6260_S00.KARBONN_KPHONE1_ NWKPD_MT6260_V006_20130928_1729.bin FileVersion : Karbonn_Kphone1_NWKPD_MT6260_V006_20130928_1729 Load File Ok Operation : Flash [ v0.03 ] ======= Flash Files set for flashing : [ MCU ] : karbonn kphone1.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 74 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : EA0093A7E2E40598A4428341DE5C32CD BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 SDS : 0x00000000 , 0x00000000 Erase region , wait ... Write data , wait ... Write : karbonn kphone1.bin Done! Elapsed: 00:01:15 Reconnect Power/Cable! |
06-26-2014, 15:40 | #8 (permalink) | |
Freak Poster Join Date: Aug 2011 Location: Uganda Age: 42
Member: 1640892 Status: Offline Sonork: 100.1651734 Thanks Meter: 25 | Quote:
br baruga | |
