07-02-2016, 15:54 | #32 (permalink) |
Major Poster Join Date: Jul 2013 Location: 127.0.0.1
Member: 1970941 Status: Offline Thanks Meter: 4 | SM-G530H nand needed I need this flash file and thanks in advance ! Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 82 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 002C00BC009000550056000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0x16F9CADB1E0F9E773C43893EF7A60BE6 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : SM-G530F ProdModel : SM-G530F Device : SM-G530F AndroidVer: 4.4.4 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:20 |
08-26-2016, 09:08 | #37 (permalink) | |
Junior Member Join Date: Oct 2010 Location: philippines
Member: 1421873 Status: Offline Sonork: louigie Thanks Meter: 11 | Quote:
Device Brand : Z5 Device Model : Z5 Device CPU : MT6572 Device IntName : Z5 Device Version : 4.4.2 Device Compile : 12/28/2015 7:43:55 AM Device Project : ALPS.KK1.MP7.V1.7 Device ExtInfo : Z5 | |
08-26-2016, 09:11 | #38 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 232 | i need datawind 3g7 tm flash file 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010034594D4433520135504EF481DD Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! |
08-27-2016, 08:13 | #39 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Faisalabad Pakistan
Member: 696491 Status: Offline Thanks Meter: 164 | Plz i need this file urgently kindly any body have backup share with me here... MT6575__TCT__ALCATEL_ONE_TOUCH_5020A__Megane_GSM__ 4.1.1__ALPS.JB.MP.V1 Preloader preloader_jrdsh75_cu_jb Device Brand : TCT Device Model : Megane_GSM Device CPU : MT6575 Device IntName : Megane Device Version : 4.1.1 Device Compile : 1/28/2014 6:23:37 AM Device Project : ALPS.JB.MP.V1 Device ExtInfo : ALCATEL ONE TOUCH 5020A |
09-03-2016, 07:42 | #41 (permalink) |
Member: 1421873 Status: Offline Sonork: louigie Thanks Meter: 11 | badly need this file, thanks in advance Device Brand : Z5 Device Model : Z5 Device CPU : MT6572 Device IntName : Z5 Device Version : 4.4.2 Device Compile : 12/28/2015 7:43:55 AM Device Project : ALPS.KK1.MP7.V1.7 Device ExtInfo : Z5 |
02-19-2017, 06:39 | #42 (permalink) | |
Member: 696491 Status: Offline Thanks Meter: 164 | Quote:
