07-19-2016, 21:03 | #63 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | Card found : S/N : 93E1A980 , v0132 Chinese Miracle II [MTK module] v 1.52 Operation : Check / Read Info [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420118FC76D2B0D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420118FC76D2B0D1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xEBB79D925855B17E474DB354675D4E87 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420118FC76D2B0D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420118FC76D2B0D1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xEBB79D925855B17E474DB354675D4E87 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Format/Reset Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Read Flash [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420118FC76D2B0D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420118FC76D2B0D1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xEBB79D925855B17E474DB354675D4E87 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Read Ok , collect info Brand : GOCLEVER ProdName : QUANTUM_350 ProdModel : QUANTUM_350 Device : goclever72_3725 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Saved to : E:\MT6572__GOCLEVER__QUANTUM_350__goclever72_3725_ _ALPS.JB3.MP.V1__Android_4.2.2.ispff Done! Elapsed: 00:08:48 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.52 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.52 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420118FC76D2B0D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420118FC76D2B0D1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xEBB79D925855B17E474DB354675D4E87 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 1 Removing infected files and scripts ... SmartAV Report : Removed 1 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Format FileSystem [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420118FC76D2B0D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420118FC76D2B0D1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xEBB79D925855B17E474DB354675D4E87 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Format/Reset Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! Operation : Format FileSystem [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420118FC76D2B0D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420118FC76D2B0D1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xEBB79D925855B17E474DB354675D4E87 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Format FileSystem [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3957524D420118FC76D2B0D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRW9 [eMMC] : FLASH_CID : 1501004E3957524D420118FC76D2B0D1 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xEBB79D925855B17E474DB354675D4E87 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Format/Reset Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! please help team to format this phone |
The Following User Says Thank You to tikourine For This Useful Post: |
07-19-2016, 22:20 | #64 (permalink) |
Freak Poster Join Date: Jul 2011 Location: South Sulawesi
Member: 1622614 Status: Offline Thanks Meter: 71 | ZENPHONE GO MTK 6580 read failed Sir 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
07-19-2016, 22:54 | #66 (permalink) |
Member: 1622614 Status: Offline Thanks Meter: 71 | Thank U Infinity Team and Thanks too Mr. Jaydi Am so Happy with this Update Chinese Miracle II [MTK module] v 1.52 Operation : Read Flash [ v1.52 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D42010F84D41833A7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0x85225F7573728CAD7C3196F91107929E INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! xGPT : Normalize settings Ok! Brand : OPPO ProdName : X9009 ProdModel : X9009 Device : X9009 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : X9009EX_11_A.19_160711 [Read Ok] : preloader_oppo6755_15111.bin [Read Ok] : recovery.img [Read Ok] : md1img.img [Read Ok] : md1dsp.img [Read Ok] : md1arm7.img [Read Ok] : lk.bin [Read Ok] : lk2.bin [Read Ok] : boot.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6755 / V1.1.2 / oppo6755_15111 / EMMC Android Info saved HWConfig Info saved FW Size : 3175 MiB Scatter saved to : C:\Users\Azhar\Desktop\MT6755__OPPO__X9009__X9009_ _5.1__X9009EX_11_A.19_160711\ All done! Done! Elapsed: 00:07:03 Reconnect Power/Cable! Screenshot by Lightshot Screenshot by Lightshot Now I have Backup File For my Phone OPPO R9 aka F1plus People Know Who the Best keep Up Infinity Team |
07-20-2016, 00:00 | #67 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 19/07/2016 17:56:59 ---------- DongleManager [Infinity-Box] v1.63 [19/07/2016 17:56:59] PC HWID: 2B6581080E337D6CDB538F12AB0B5BD6 Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0001D8AB00001942 Type: Main Infinity-Box/Dongle S/N: 9302D8AB Version: 0130.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. No updates found for your Smart-Card. DO NOT try more today ! |
07-20-2016, 06:32 | #74 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | Box/Dongle type selected: inf Box/Dongle found: inf ---------- Process started: 7/20/2016 10:29:15 AM ---------- DongleManager [Infinity-Box] v1.61 [7/20/2016 10:29:15 AM] PC HWID: 3F154A93A10BCFDD93BA6C96EA33AA75 Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00043448FF021982 Type: inf S/N: 4F3E3448 Version: 0130.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! |
07-20-2016, 06:36 | #75 (permalink) |
No Life Poster Join Date: May 2006 Location: heLL and beY0nd
Member: 281801 Status: Offline Sonork: 100.1608672 Thanks Meter: 158 | WHAT MEAN BY THIS That allow flashing those factory files on phones with different memory sizes without further problems with user memory PLEASE, QUALCOMM SP UNLOCK & FLASHING SUPPORT NEEDED ZTE, qmobile, and others |
