Infinity Chinese Miracle-2 MTK/Mediatek v2.00 r4 - MT6771 support and other features Infinity Chinese Miracle-2 MTK/Mediatek v2.00 r4 - MT6771 support and other features ! - Main Connection level revised BROM level support optimized MT6771 CPU supported! MT6771 moved from TEST to GENERAL support. Firmwware read Firmware write NVRAM read NVRAM write Reset Settings / Format FS Reset FRP Reset Privacy MemoryTool - Service Repair Security revised. Fixed issues with some NV types. - Core EMIDB updated Hint/Error explain module updated MT6758 support under test MT6765 support under test - FW reader MT6771 supported New types of firmwares supported Scatter creation optimized - SP Unlock Revised unlock support for some models Info: MT6739/MT6763/MT6771 IS NOT supported YET! - New models included Limited Oppo support (F7/A3) Limited Vivo support And diffirent other models Some other basic "generic" secure devices support optimized Known issues/warnings/info: 1. [NAND on MT6570] v1712, v1736 loader packages SHOULD NOT BE USED due to these packages have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal behaviour and can not be fixed. Read-Write data, which you want, ignore "EMPTY" states. 4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing 5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases! 7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list! 8. [NAND on MT6570] In some cases device MAY DEAD after flashing! Make sure you have TESTED firmware version! If you have download FW from internet/other source - make sure it preloader CONTAIN 3 EMI record! Preloader jc45btlc with 2 records KILL SOME DEVICE TO UNRECOVERABLE STATE!!! Preloader info shown now during FW load. Credits : kamal_singla - testing and useful files contribution Important: - Software installed to new folder /CM2MT2/ and designed to support new models - Smart-Card firmware v0136 is Ok to use this version - DO NOT uninstall previous version 1.58 ! If you are trying to connect phone with new software and see a message like LEGACY MTK you should use version 1.58 for this device ! Download link Upload file to Support Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News Twitter - Facebook - Telegram |
IMPORTANT NOTE ! After install folder /CM2MT2/boot/oppo/A3/ should have only one file Oppo.F7.link If you will see any problem with A3 model please check boot file folder and delete bin files, leave only Oppo.F7.link file there. |
Great think OPPO F7,,, Can it network unlock possible,, if not,,, what is that main think,,, please say details,,,,, |
https://i.imgur.com/Q67RRtw.png |
we need more strong update... |
cm2 update full fato plz sir update strong |
very very thnx for continue updating MTK new boot and probs thnx infinty team we are waiting Thunder update BR: Qaiser |
fixed f3 1609 not supported check team |
I dont like yours last few new update of mtk.. Its only full blank update.... Hope team give best and strong update... Dont give single mtk ipdate... Infinity give after 2 year mtk update not usefullll.... Only time waste..... |
thanks for update please added huawei and other secure boots models |
good updates thnx team keep it up |
Very Use Full Update Thanks Team CM2 |
