Old 06-06-2018, 09:03   #1 (permalink)
Member: 148515
Thanks Meter: 19,534
Infinity Chinese Miracle-2 MTK/Mediatek v2.00 r4 - MT6771 support and other features
Infinity Chinese Miracle-2 MTK/Mediatek v2.00 r4 - MT6771 support and other features !
- Main
Connection level revised
BROM level support optimized
MT6771 CPU supported!
MT6771 moved from TEST to GENERAL support.
Firmwware read
Firmware write
NVRAM read
NVRAM write
Reset Settings / Format FS
Reset FRP
Reset Privacy
MemoryTool
- Service
Repair Security revised. Fixed issues with some NV types.
- Core
EMIDB updated
Hint/Error explain module updated
MT6758 support under test
MT6765 support under test
- FW reader
MT6771 supported
New types of firmwares supported
Scatter creation optimized
- SP Unlock
Revised unlock support for some models
Info: MT6739/MT6763/MT6771 IS NOT supported YET!
- New models included
Limited Oppo support (F7/A3)
Limited Vivo support
And diffirent other models
Some other basic "generic" secure devices support optimized
Known issues/warnings/info:
1. [NAND on MT6570] v1712, v1736 loader packages SHOULD NOT BE USED due to these packages have ftl/ecc errors!
In result you will give read/write FW errors and rest problems at all.
Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write
2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format!
3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal behaviour and can not be fixed.
Read-Write data, which you want, ignore "EMPTY" states.
4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing
5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list.
6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases!
7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list!
8. [NAND on MT6570] In some cases device MAY DEAD after flashing! Make sure you have TESTED firmware version!
If you have download FW from internet/other source - make sure it preloader CONTAIN 3 EMI record! Preloader jc45btlc with 2 records KILL SOME DEVICE TO UNRECOVERABLE STATE!!!
Preloader info shown now during FW load.
Credits :
kamal_singla - testing and useful files contribution
Important:
- Software installed to new folder /CM2MT2/ and designed to support new models
- Smart-Card firmware v0136 is Ok to use this version
- DO NOT uninstall previous version 1.58 ! If you are trying to connect phone with new software and see a message like LEGACY MTK you should use version 1.58 for this device !
Download link
Upload file to Support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
The Following 82 Users Say Thank You to InfinityHelp For This Useful Post:
Old 06-06-2018, 09:09   #2 (permalink)
Member: 148515
IMPORTANT NOTE !
After install folder /CM2MT2/boot/oppo/A3/ should have only one file Oppo.F7.link
If you will see any problem with A3 model please check boot file folder and delete bin files, leave only Oppo.F7.link file there.
The Following 14 Users Say Thank You to InfinityHelp For This Useful Post:
Old 06-06-2018, 09:29   #3 (permalink)
Registered User
Member: 1021931
Thanks Meter: 128
Great think OPPO F7,,,
Can it network unlock possible,,
if not,,, what is that main think,,,
please say details,,,,,
The Following User Says Thank You to noyon_nyn For This Useful Post:
Old 06-06-2018, 09:39   #4 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
IMPORTANT NOTE !
this file
Old 06-06-2018, 09:57   #5 (permalink)
scorpian1982's Avatar
Member: 2192793
Thanks Meter: 188
Originally Posted by nahidroman View Post
this file
nooooo my dear, leave this file only and if you see any other file in this folder delete that files. . .
The Following 6 Users Say Thank You to scorpian1982 For This Useful Post:
Old 06-06-2018, 11:36   #6 (permalink)
Member: 2552533
Thanks Meter: 93
we need more strong update...
The Following 2 Users Say Thank You to blushi For This Useful Post:
Old 06-06-2018, 12:14   #7 (permalink)
Member: 2219498
Sonork: 100.1669861
Thanks Meter: 69
cm2 update full fato plz sir update strong
The Following User Says Thank You to nilpori For This Useful Post:
Old 06-06-2018, 12:35   #8 (permalink)
Member: 1185918
Sonork: 100.1617322
Thanks Meter: 428
very very thnx for continue updating MTK new boot and probs
thnx infinty team
we are waiting Thunder update
BR:
Qaiser
The Following 2 Users Say Thank You to qasir_amz For This Useful Post:
Old 06-06-2018, 12:36   #9 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
fixed f3 1609 not supported
check team
Old 06-06-2018, 12:37   #10 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
check team
what issue please post screenshot or logs
The Following 2 Users Say Thank You to kamal_singla For This Useful Post:
Old 06-06-2018, 12:41   #11 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
check team
Not Supported log Post
The Following 2 Users Say Thank You to nahidroman For This Useful Post:
Old 06-06-2018, 12:46   #12 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 205
I dont like yours last few new update of mtk..
Its only full blank update....
Hope team give best and strong update...
Dont give single mtk ipdate...
Infinity give after 2 year mtk update
not usefullll....
Only time waste.....
The Following 6 Users Say Thank You to RIZU007 For This Useful Post:
Old 06-06-2018, 12:56   #13 (permalink)
Member: 2355681
Thanks Meter: 78
thanks for update please added huawei and other secure boots models
Old 06-06-2018, 13:14   #14 (permalink)
umerkhalid1992's Avatar
Member: 2696842
Sonork: 100.1683002
Thanks Meter: 296
good updates thnx team keep it up
Old 06-06-2018, 13:25   #15 (permalink)
Member: 2363063
Sonork: 100.1683216
Thanks Meter: 3
Very Use Full Update Thanks Team CM2
The Following 2 Users Say Thank You to asadhussain2 For This Useful Post:
Page generated in 0.24689 seconds with 8 queries
