Infinity Chinese Miracle-2 MTK/Mediatek v2.01 - LEGACY support and other features Infinity Chinese Miracle-2 MTK/Mediatek v2.01 - LEGACY support and other features Important: - Software installed to new folder /CM2MT2/ and designed to support new models Legacy core support activated: MT6571 MT6572 MT6580 MT6582 MT6589 MT6592 MT6595 MT6597 MT6732 MT6735 MT6737 MT6752 MT6753 MT6795 MT8127 MT8163 MT8321 MT8732 MT8735 MT8752 Identify: full device info, security info Flash Factory Firmware Read Factory Firmware Reset Settings / Format FS Reset FRP Repair Security (Flash Mode, Direct) SP unlock MemoryTool - complete device control, service, repair, forensic etc. - Main Loader database optimized, size reduced. DA v1820 line support tested and activated DA v1836 line support tested and activated Connection level revised BROM level support optimized Optimized and changed HighSpeed port selection FlashEngine revised NVRAM tool revised Global option PWM - allow switch SW between two different work modes for RAPHAEL. > Use second one if first mode give errors at writing f.e. restore NVRAM on F5 like device etc. > For LEGACY phone it used in MEMORY TOOL ( WRITE / WIPE ) - Service Repair Security revised > Old LEGACY types require FORMAT FS/FACTORY RESET for accept changes ! Format FS - new mode activated: Forced Erase Format FS - fixed WIPE mode - Core EMIDB updated New EMI engine for LEGACY line > EMI engine support almost all existing LEGACY line > New types for RAPHAEL included - FW reader LEGACY core supported ( unsigned and static signed types are supported ) New types of firmwares supported Scatter creation optimized - Other Settings tab activated ( firmware path settings and other features can be found here ) AutoUpdate ( module files ) feature activated Many other changes and fixes Known issues/warnings/info: 1. FileSystem flashing on some SBC-enabled RAPHAEL devices (except SYSTEM/CACHE/USER) may fail ! Solution - exclude them from flashing list. 2. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list ! 3. MT6589 supported ONLY up to DAv17xx line, after DAv1728 support has been removed. 4. MT6592 support on DAv18xx loader line broken ( DA issue ) 5. EMI/DRAM init module in LEGACY line is almost auto, but in some case require CHANGE EMI setting, if used internal DB ( since much RAMsize/Revision of eMMC/eMCP ) 6. MOST of LEGACY phone can be booted via BROM mode from now ( PLAIN, PRL, SBC ) 7. NAND support on LEGACY line is not activated yet Download link Subscribe to Telegram channel and get news faster ! How to upload files to support Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News Twitter - Facebook - Telegram |
Please Add Important Functions TEST EMMC & RAM |
Excellent news I was tired of always modifying DA to be able to work the segurity boot http://i63.tinypic.com/2hp1w0h.jpg Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D42014FC7E4FD34D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D42014FC7E4FD34D1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0F4DE466E0CA9B7FA0575DCA58EB665C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : motorola ProdName : watson_50 ProdModel : Moto C Device : watson AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-n0.mp2-V1_wt6580.we.n_P38 Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
mtk lock screen without lost data |
world first update,but everybody please renew your cm2 dongle otherwise not possible to use. |
Good update, team add support for TEST HARDWARE READ/WRITE EMMC AND RAM |
Not able to update dongle showing error ( no more update dont try again today ) Dongle manager version 1.72 |
how to update our dongle for this update to work? |
need use this version without renewal https://i.imgur.com/T3xz8VO.png https://i.imgur.com/lfpsJGn.png |
same here , same error showing |
great update. Add .... add sreen lock remove wo lost data. EMMC Test we need update for SPD module plz. You are the best |
please support mobicel rebel privacy lock mtk legacy , full factory reset all not working to remove privacy |
Time to Renew support, Check dongle support Expiry date. How to check here https://www.infinity-box.com/doc.php?id=17 If Expired contact your Nearest Resellers for Support Renewal. |
Plz TEam Add Latest Oppo Secure MTK Chip.... Thanks For This Update . |
