Old 11-06-2018, 23:22   #1 (permalink)
Member: 148515
Thanks Meter: 13,926
Infinity Chinese Miracle-2 MTK/Mediatek v2.01 - LEGACY support and other features
Important:
- Software installed to new folder /CM2MT2/ and designed to support new models
Legacy core support activated:
MT6571
MT6572
MT6580
MT6582
MT6589
MT6592
MT6595
MT6597
MT6732
MT6735
MT6737
MT6752
MT6753
MT6795
MT8127
MT8163
MT8321
MT8732
MT8735
MT8752
Identify: full device info, security info
Flash Factory Firmware
Read Factory Firmware
Reset Settings / Format FS
Reset FRP
Repair Security (Flash Mode, Direct)
SP unlock
MemoryTool - complete device control, service, repair, forensic etc.
- Main
Loader database optimized, size reduced.
DA v1820 line support tested and activated
DA v1836 line support tested and activated
Connection level revised
BROM level support optimized
Optimized and changed HighSpeed port selection
FlashEngine revised
NVRAM tool revised
Global option PWM - allow switch SW between two different work modes for RAPHAEL.
> Use second one if first mode give errors at writing f.e. restore NVRAM on F5 like device etc.
> For LEGACY phone it used in MEMORY TOOL ( WRITE / WIPE )
- Service
Repair Security revised
> Old LEGACY types require FORMAT FS/FACTORY RESET for accept changes !
Format FS - new mode activated: Forced Erase
Format FS - fixed WIPE mode
- Core
EMIDB updated
New EMI engine for LEGACY line
> EMI engine support almost all existing LEGACY line
> New types for RAPHAEL included
- FW reader
LEGACY core supported ( unsigned and static signed types are supported )
New types of firmwares supported
Scatter creation optimized
- Other
Settings tab activated ( firmware path settings and other features can be found here )
AutoUpdate ( module files ) feature activated
Many other changes and fixes
Known issues/warnings/info:
1. FileSystem flashing on some SBC-enabled RAPHAEL devices (except SYSTEM/CACHE/USER) may fail ! Solution - exclude them from flashing list.
2. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list !
3. MT6589 supported ONLY up to DAv17xx line, after DAv1728 support has been removed.
4. MT6592 support on DAv18xx loader line broken ( DA issue )
5. EMI/DRAM init module in LEGACY line is almost auto, but in some case require CHANGE EMI setting, if used internal DB ( since much RAMsize/Revision of eMMC/eMCP )
6. MOST of LEGACY phone can be booted via BROM mode from now ( PLAIN, PRL, SBC )
7. NAND support on LEGACY line is not activated yet
Download link
Subscribe to Telegram channel and get news faster !
How to upload files to support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
The Following 103 Users Say Thank You to InfinityHelp For This Useful Post:
Old 11-06-2018, 23:39   #2 (permalink)
Member: 2108610
Thanks Meter: 181
Please Add Important Functions TEST EMMC & RAM
The Following 5 Users Say Thank You to yosbel182us For This Useful Post:
Old 11-06-2018, 23:59   #3 (permalink)
Member: 790437
Thanks Meter: 34
Excellent news I was tired of always modifying DA to be able to work the segurity boot
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : LOCKED with CERT
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464E58324D42014FC7E4FD34D1
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D42014FC7E4FD34D1
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x0F4DE466E0CA9B7FA0575DCA58EB665C
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : motorola
ProdName : watson_50
ProdModel : Moto C
Device : watson
AndroidVer: 7.0
MTKxCPU : MT6580
MTKxPRJ : alps-mp-n0.mp2-V1_wt6580.we.n_P38
Done!
Elapsed: 00:00:08
Reconnect Power/Cable!
The Following 5 Users Say Thank You to caldasunlockgsm For This Useful Post:
Old 11-07-2018, 00:04   #4 (permalink)
Member: 2324451
Thanks Meter: 15
mtk lock screen without lost data
Old 11-07-2018, 03:21   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 700
world first update,but everybody please renew your cm2 dongle otherwise not possible to use.
The Following User Says Thank You to kothamamun For This Useful Post:
Old 11-07-2018, 04:03   #6 (permalink)
Member: 2381725
Thanks Meter: 35
Good update, team add support for TEST HARDWARE READ/WRITE EMMC AND RAM
Old 11-07-2018, 04:35   #7 (permalink)
logicmobile's Avatar
Member: 1016569
Thanks Meter: 227
Not able to update dongle
showing error ( no more update dont try again today )
Dongle manager version 1.72
Old 11-07-2018, 04:51   #8 (permalink)
Member: 2834928
how to update our dongle for this update to work?
Old 11-07-2018, 04:54   #9 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Sonork: 100.1645446
Thanks Meter: 806
need use this version without renewal
The Following 3 Users Say Thank You to >>Gsmmilon>> For This Useful Post:
Old 11-07-2018, 05:05   #10 (permalink)
Member: 1016569
Thanks Meter: 227
same here , same error showing
The Following User Says Thank You to logicmobile For This Useful Post:
Old 11-07-2018, 05:31   #11 (permalink)
localizator's Avatar
Member: 2550141
Thanks Meter: 847
For CM2MT2 2.01 need smard card firmware version 1.37. Renew support and update smard card with dongle manager
The Following 4 Users Say Thank You to localizator For This Useful Post:
Old 11-07-2018, 05:53   #12 (permalink)
Member: 2708690
Thanks Meter: 5
great update. Add ....
add sreen lock remove wo lost data.
EMMC Test
we need update for SPD module plz.
You are the best
The Following 2 Users Say Thank You to nasch For This Useful Post:
Old 11-07-2018, 06:03   #13 (permalink)
bright hlatini's Avatar
Member: 1614640
Sonork: 100.1625899
Thanks Meter: 437
please support mobicel rebel privacy lock mtk legacy , full factory reset all not working to remove privacy
The Following 2 Users Say Thank You to bright hlatini For This Useful Post:
Old 11-07-2018, 06:10   #14 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,253
Hello,
Time to Renew support,
Check dongle support Expiry date.
How to check here https://www.infinity-box.com/doc.php?id=17
If Expired contact your
Nearest Resellers for Support Renewal.
Old 11-07-2018, 06:19   #15 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 433
Plz TEam Add Latest Oppo Secure MTK Chip....
Thanks For This Update .
The Following 2 Users Say Thank You to ahmer5050 For This Useful Post:
Page generated in 0.42545 seconds with 7 queries
