11-07-2018, 14:44 | #31 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Load IDBase v11554 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! |
11-07-2018, 17:44 | #39 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Windows 7 & 8.1 64bit Not Open Tested by me on Fresh windows Xp Opens fine. |
The Following User Says Thank You to Kirumira For This Useful Post: |
11-07-2018, 17:51 | #40 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Run. Make sure there is no any fault.bin appeared. Make sure your system clean from viruses and other stuff. Wait some time after installation, if your system have installed AV software. Make sure in software folder not exists any other files, except setup makes ( uk just additional one ) - other not should present at all. | |
11-07-2018, 18:33 | #42 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
All you mentioned has already done, No Antivirus No faultybin I installed New Os several times because of this Update. Still no Open. Let keep using Xp for this update till futher solution | |
11-07-2018, 19:30 | #45 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Russia, Ivanovo city
Member: 2006990 Status: Offline Thanks Meter: 540 | Please Help Me ==== [07.11.2018 14:17:25] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.72 [07.11.2018 14:17:28] === Searching... Card-Reader: FT SCR2000 0 HWID: 01028D6514D11292 Box/Dongle found: [BEST] Serial No (S/N): 7******* Firmware version: 0122.02 "UK Edition" status: Off Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v.0136 - 03: [BEST] v.0122 - 07: #7 Token - Type: Infinity [BEST] - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; Firmware Version: 0137; Registered: 19-Jan-2016; Expired: 08-Nov-2019; Support: Active - Activation 2: Infinity [BEST]; S/N: 7*******; Firmware Version: 0122 - Activation 3: Infinity SM - More Services may be active but not listed |
