11-11-2018, 11:41 | #1 (permalink) |
Freak Poster Join Date: Sep 2014 Location: MOZAMBIQUE
Member: 2263412 Status: Offline Thanks Meter: 86 | Infinity Chinese Miracle-2 MTK/Mediatek v2.02 - LEGACY support and BUG FIXED Important: - Software installed to new folder /CM2MT2/ and designed to support new models Legacy core support activated: MT6571 MT6572 MT6580 MT6582 MT6589 MT6592 MT6595 MT6597 MT6732 MT6735 MT6737 MT6752 MT6753 MT6795 MT8127 MT8163 MT8321 MT8732 MT8735 MT8752 Identify: full device info, security info Flash Factory Firmware Read Factory Firmware Reset Settings / Format FS Reset FRP Repair Security (Flash Mode, Direct) SP unlock MemoryTool - complete device control, service, repair, forensic etc. - Main Loader database optimized, size reduced. DA v1820 line support tested and activated DA v1836 line support tested and activated Connection level revised BROM level support optimized Optimized and changed HighSpeed port selection FlashEngine revised NVRAM tool revised Global option PWM - allow switch SW between two different work modes for RAPHAEL. > Use second one if first mode give errors at writing f.e. restore NVRAM on F5 like device etc. > For LEGACY phone it used in MEMORY TOOL ( WRITE / WIPE ) - Service Repair Security revised > Old LEGACY types require FORMAT FS/FACTORY RESET for accept changes ! Format FS - new mode activated: Forced Erase Format FS - fixed WIPE mode - Core EMIDB updated New EMI engine for LEGACY line > EMI engine support almost all existing LEGACY line > New types for RAPHAEL included - FW reader LEGACY core supported ( unsigned and static signed types are supported ) New types of firmwares supported Scatter creation optimized - Other Settings tab activated ( firmware path settings and other features can be found here ) AutoUpdate ( module files ) feature activated Many other changes and fixes Known issues/warnings/info: 1. FileSystem flashing on some SBC-enabled RAPHAEL devices (except SYSTEM/CACHE/USER) may fail ! Solution - exclude them from flashing list. 2. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list ! 3. MT6589 supported ONLY up to DAv17xx line, after DAv1728 support has been removed. 4. MT6592 support on DAv18xx loader line broken ( DA issue ) 5. EMI/DRAM init module in LEGACY line is almost auto, but in some case require CHANGE EMI setting, if used internal DB ( since much RAMsize/Revision of eMMC/eMCP ) 6. MOST of LEGACY phone can be booted via BROM mode from now ( PLAIN, PRL, SBC ) 7. NAND support on LEGACY line is not activated yet GREAT |
The Following User Says Thank You to pink009 For This Useful Post: |
