Old 01-03-2019, 12:25   #46 (permalink)
Member: 2082450
Thanks Meter: 1,417
Originally Posted by GODISTHEBEST View Post
ok thank you but i knew that so i am asking if ...
CM2 is the addition software of miracle box ? or it infinity product that diffrant from "miracle box" ?
Both are different box from different manufacturer. And the truth is CM2 is genuine working to while the other use just there copy paste tool..
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 01-03-2019, 15:19   #47 (permalink)
Member: 2496790
Thanks Meter: 5
SO I UNDERSTAND THAT ALL THAT miraaacle box have the CM2 for sure have it ?
Old 01-04-2019, 07:46   #48 (permalink)
Member: 2243017
Thanks Meter: 9
pleas team update spd also
The Following User Says Thank You to haider420 For This Useful Post:
Old 01-04-2019, 07:56   #49 (permalink)
ali-f16's Avatar
Member: 1824614
Sonork: ali_f*******[email protected]
Thanks Meter: 88
Scanning devices ...1 found
dev[1] b131076b7d28
Mode: normal
Hardware: mt6765
Manufactory: XIAOMI
Model: REDMI 6A
Error : Fail to init protocol!
Operation : Identify [ v2.03 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM98)
MODE : BOOTROM
PORT : 98
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+ARB
BROM : BOOTROM
MODE : 0_base : BASE_v1844 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00000001 : DA SEND ERROR!
ERROR : BROM : DL MODE ERROR
INFO : BROM Level : SLA AUTH or AUTH required!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
The Following User Says Thank You to ali-f16 For This Useful Post:
Old 01-04-2019, 14:55   #50 (permalink)
Member: 931121
Thanks Meter: 57
symphony v20 format done
Card found : 64C1CE3F , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.03
Load IDBase v123080 Ok!
Update configuration ...
Socket Error # 11001
Host not found.
Update failed! Check settings and/or internet connection!
PTFN : MediaTek PreLoader USB VCOM Port (COM9)
MODE : PRELOADER PORT
PORT : 9
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Found MT6570
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x20000000 [ 512.00 MB ]
EMMC: 7001004D36323730340112DC4101446B
EMMC: VEN : KINGSTON | OEM : 01 | DEV : M62704
EMMC:
BOOT1 : 0x00200000 [ 2.00 MB ]
BOOT2 : 0x00200000 [ 2.00 MB ]
RPMB : 0x00080000 [ 512.00 KB ]
USER : 0xE2000000 [ 3.53 GB ]
CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : FF82FBE4D93700D8FF3AB9C0A837A440
DA : USB : HIGH-SPEED
Boot done!
Patch Level : MRA58K
Display ID : V20_HW1_V6
Ver. CodeName : REL
Ver. Release : 6.0
Sec. Patch : 2017-05-05
Build Time : 1495765973
Product Model : roar V20
Product Brand : Symphony
Product Name : full_sr6570_cweg_m
Product Device : roar V20
Product Manfct : Symphony
Board Platform : mt6570
Product Info : sr6570_cweg_m
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:28
Operation : Reset Settings/Format FS [ v2.03 ]
PORT : 9
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:22
The Following 2 Users Say Thank You to moniuzzaman For This Useful Post:
Old 01-04-2019, 15:50   #51 (permalink)
Member: 1043909
Thanks Meter: 48,917
Dear Sir,
Let me remind you that current thread is about MTK but as a exception your request has been forwarded to development department.
Old 01-04-2019, 15:53   #52 (permalink)
Member: 1043909
I understand nothing.
What do you want to ask ?
If you need good software see this - https://www.infinity-box.com/price.php
Old 01-05-2019, 06:57   #53 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 3,644
PTFN : MTK USB Port (COM23)
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : BOOTROM
AGENT : Found MT6739
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 0003
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH_MISMATCH
try once without hold any key in preloader mode and post logs
Old 01-05-2019, 09:24   #54 (permalink)
Member: 2803352
Thanks Meter: 3
Originally Posted by mathugu2[email protected] View Post
MT2 v203 not open mistake foud somewhere
M2MT2 2.3 not openning solution here
Old 01-05-2019, 13:35   #55 (permalink)
Member: 1043909
@faisal naeem
link removed to avoid confusion and misunderstanding.
the only solution is - install latest CM2MT2 software from support area.
Old 01-06-2019, 02:40   #56 (permalink)
Member: 2256516
Thanks Meter: 2
Please support for flashing oppo and vivo new security model..
thanks infinity team
The Following User Says Thank You to alzam For This Useful Post:
Old 01-06-2019, 10:54   #57 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 568
lovely my super best team ..nice nice update
Old 01-06-2019, 11:45   #58 (permalink)
ARS.Rehman's Avatar
Member: 491455
Sonork: 100.1608065
Thanks Meter: 278
Originally Posted by YellowBoss View Post
please post operation log text with this device. Thank you !
oppo f5 cph1723
PTFN : PreLoader USB VCOM (Android) (COM3)
PORT : 3
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
MODE : Oppo : F5 | Manual : Disabled
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
BROM : 0x00002001 : DA SEND ERROR!
ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC
Old 01-06-2019, 19:22   #59 (permalink)
Member: 1477125
Thanks Meter: 74
Originally Posted by ARS.Rehman View Post
oppo f5 cph1723
PORT : 3
BROM : Init BROM
BROM init passed!
Force bootrom mode....open phone and short
Go here...
World First Oppo F5 CPH1723 Full Firmware Read with CM2MT2 V30 Latest Security Patch
Old 01-07-2019, 10:24   #60 (permalink)
Member: 2560322
Sonork: hello guys this is isaiah
just by clicking identify this pops up without the phone being connected
PTFN : MediaTek DA USB VCOM Port (COM22)
PORT : 22
Error : Failed to open port!
Page generated in 0.23719 seconds with 7 queries
