Old 02-10-2019, 12:27   #166 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,197
@vivekk, change EMI settings from 0 to 1, then to 2. Should work with one of them.
Old 02-10-2019, 12:28   #167 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by ali-f16 View Post
Operation : Identify [ v2.04 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM8)
MODE : PRELOADER PORT
PORT : 8
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode  : SBC
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1820 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00002001 : DA SEND ERROR!
  ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
  INFO : PRELOADER Level : Connect device in BROM mode!
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Try read that string. Just try and do as SW ask.
The Following User Says Thank You to JayDi For This Useful Post:
Old 02-10-2019, 12:38   #168 (permalink)
ali-f16's Avatar
Member: 1824614
Sonork: ali_f*******[email protected]
Thanks Meter: 88
PORT : 8
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
Old 02-10-2019, 17:41   #169 (permalink)
Member: 2628926
Sonork: firozansari970
oppo f7 cm2 earr issue not frp and furmat
Old 02-11-2019, 07:11   #170 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 605
PORT : 8
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
Hello,
In simple words hold vol keys and connect
The Following User Says Thank You to princesaddam For This Useful Post:
Old 02-11-2019, 07:12   #171 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 605
Hello,
Wht error ur getting Plz post logs for better help,,BTW if u have latest Patch then plz do it with TP for more info read this theard F5/A83 "NEW" security O_o
Old 02-11-2019, 13:19   #172 (permalink)
Member: 921036
Thanks Meter: 80
Card found : 186B717D , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.04
Load IDBase v123080 Ok!
Operation : Repair Security [ v2.04 ]
PTFN : MediaTek USB Port (COM32)
MODE : BOOTROM
PORT : 32
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+ARB
BROM : BOOTROM
MODE : Oppo : F7 | Manual : Enabled
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 01: 102A 0001
BROM : SOCID : E79292E77A174956429210ECC52AE22C8F466205EB69F79C18 FB9C47D9DCEEDC
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
AGENT : DA_BR_HIGH.bin
AGENT : Found MT6771
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v1
EMI : CNT : 000D
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH_MISMATCH
MODE : BOOTROM
PORT : 32
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : 2
EMI : CNT : 0000
DA : SETUP EMI PARAMS FAILED!
ERROR : DA_EXCEED_MAX_NUM
Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
same problem...
Old 02-11-2019, 18:19   #173 (permalink)
Member: 2744335
Awesome update! Keep up the great work!
Old 02-12-2019, 08:38   #174 (permalink)
Member: 1958094
Thanks Meter: 36
FRP and Format not successful
BASE_v1904, v1844, v1836, v1820
Operation : Reset Settings/Format FS [ v2.04 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM31)
PORT : 31
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
MODE : 0_base : BASE_v1904 | Manual : Disabled
AGENT : Found MT6739
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
EMMC: 150100464536324D4203A61B7A47503
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : F4AB758653441F802B5D5B7E5DA85DBD
DA : USB : HIGH-SPEED
Boot done!
ERR : 0xC0020004
ERR : SEC_DL_FORBIDDEN
ERR : 0x00000000|0x085799F4
Error : Failed erase block!
Try select another format mode!
Old 02-12-2019, 11:41   #175 (permalink)
Bimal Shah's Avatar
Member: 1050365
Thanks Meter: 64
Vivo Y91 PD1818DF
Vivo Y91 PD1818DF Hang on Logo after reset setting With cm2 and reset failed with recovery mode But thanks CM2 problem solved with flashing with CM2 readed File Log below
Read Firmware :
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM15)
PORT : 15
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : SecLevel : 0x00000005
MODE : Vivo : Y83 | Manual : Disabled
AGENT : MTK_AllInOne_DA_VIP.bin
AGENT : Found MT6765
BROM : DA sent
DA : AGENT started!
DA : SYNC
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x30000000 [ 768.00 MB ]
EMMC: 150100475036424D42016449AA7B95B7
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GP6BMB
EMMC:
RPMB : 0x01000000 [ 16.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : BEB24BA7EF87228C803AE06952DFBF71
Boot done!
Patch Level : O11019
Display ID : O11019 release-keys
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-11-05
Build Time : 1545052473
Product Model : vivo 1815
Product Brand : vivo
Product Name : PD1818CF_EX
Product Device : PD1818CF_EX
Product Manfct : vivo
Product Info : k62v1_64_bsp
Product Board : k62v1_64_bsp
Board Platform : mt6765
MT6765__vivo__vivo_1815__8.1.0__O11019__k62v1_64_b sp
Read : preloader.bin
Read : recovery.img
Read : backup.img
Read : survival.img
Read : cust.img
ExtSparse : Compression ratio : 97%
Read : persist.img
ExtSparse : Compression ratio : 100%
Read : proinfo.img
Read : efuse.img
Read : md1rom.img
Read : md1dsp.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : tinysys-sspm.bin
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : odmdtbo.img
Read : tz.img
Read : vendor.img
ExtSparse : Compression ratio : 53%
Read : system.img
ExtSparse : Compression ratio : 21%
Read : cache.img
Read : userdata.img
FW Size : 4.47 GB
Android Info saved : _Android_info.txt
Scatter : MT6765_Android_scatter.txt
Saved to : C:\Users\Bimal\Desktop\MT6765__vivo__vivo_1815__8. 1.0__O11019__k62v1_64_bsp\
Done!
Elapsed: 00:04:46
Reset Settings:
PORT : 15
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Done!
Elapsed: 00:00:25
Write Flash:
Operation : Write Flash [ v2.04 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Files :21
[FL] : Set : preloader_k62v1_64_bsp.bin
[FL] : Set : recovery.img
[FL] : Set : cust.img
[FL] : Set : efuse.img
[FL] : Set : md1rom.img
[FL] : Set : md1dsp.img
[FL] : Set : spmfw.img
[FL] : Set : tinysys-scp.bin
[FL] : Set : tinysys-sspm.bin
[FL] : Set : lk.bin
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : odmdtbo.img
[FL] : Set : tz.img
[FL] : Set : tz.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0xF1F04A10 [ 3.78 GB ]
PTFN : MediaTek USB Port_V1632 (COM23)
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001]
BROM : SOCID : 809F4C3EE1E5E6199FB07D81AF7285CA7B1BBD5B5F15E8C19F F003BD3781EF82
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6765
EMI : SRC : preloader_k62v1_64_bsp.bin
EMI : CNT : 0008
EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ]
EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ]
EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ]
EMI : Init EMI from PRELOADER
EMMC:
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
OK
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000005688000
Erase : 0x0000000007688000 : 0x0000000004000000
Erase : 0x0000000010A88000 : 0x0000000006000000
Erase : 0x0000000018000000 : 0x0000000000800000
Erase : 0x000000001B800000 : 0x0000000000200000
Erase : 0x000000001BD00000 : 0x0000000009980000
Erase : 0x0000000029680000 : 0x0000000007180000
Erase : 0x0000000080800000 : 0x0000000E0B4FBE00
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : RECOVERY
Write : CUST
Write : EFUSE
Write : MD1IMG
Write : MD1DSP
Write : SPMFW
Write : SCP1
Write : SCP2
Write : SSPM_1
Write : SSPM_2
Write : LK
Write : LK2
Write : BOOT
Write : LOGO
Write : ODMDTBO
Write : TEE1
Write : TEE2
Write : SYSTEM
Write : CACHE
Write : USERDATA
OK
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:02:26
The Following 2 Users Say Thank You to Bimal Shah For This Useful Post:
Old 02-12-2019, 12:04   #176 (permalink)
Member: 2856315
Thanks Meter: 6
Card Update failed!!!!!!!!!!!!!!!!!!
In Card Updater It shows No Update for card ,,,
But After Open Mt2 software it asks for update my card
says , Dongle version is too low!!!
What Can I do Now?? Suggesion Please!!
Info Bellow......
=== DongleManager [Infinity] v1.70 [2/12/2019 17:23:57] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 000116CA131.....
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 8CD51....
Firmware version: 0136.02
=== Process started: 2/12/2019 17:23:59 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
Old 02-12-2019, 12:16   #177 (permalink)
Member: 621121
Thanks Meter: 340
BROM : 0x00007024 : DA SEND ERROR!
LAVA iris 88
HW2618 VER: H001_INT/S114
frp locked phone
Operation : Identify [ v2.03 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM87)
PORT : 87
BROM : Init BROM
BROM init passed!
     CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002
MODE : BQ : SEC_6739 | Manual : Disabled
AGENT : DA_PL.bin
  ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE!
  INFO : Unknown reason : Check cable and battery!
Old 02-12-2019, 15:19   #178 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 605
Info Bellow......
Reading...
Hello,
It looks like your dongle support period is expired.
How to check - https://forum.infinity-box.com/viewtopic.php?f=3&t=1097
If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/
Old 02-12-2019, 15:20   #179 (permalink)
Member: 1010626
Sonork: using fb
Thanks Meter: 605
Originally Posted by alamgir80 View Post
LAVA iris 88
frp locked phone
PORT : 87
BROM : Init BROM
BROM init passed!
AGENT : DA_PL.bin
Hello,
Hold volkeys and connect,,and try selecting base Models
Old 02-15-2019, 10:41   #180 (permalink)
Member: 905522
This is what am getting from my old dongle. (Dongle firmware version : v0136) dongle firmware version is outdates! Download "donglemanager"from support and update firmware! There is no new update on dongle manager
Page generated in 0.47690 seconds with 8 queries
