04-28-2019, 21:16 | #1 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 MTK/Mediatek v2.06 - AutomaticBoot selection and more... To use this software Smart-Card firmware version should be 0137 or higher. Base: Base - Secure boot - Automatic boot selection feature released Base - Secure boot: Allow automatic detect boot configuration for SECURE enabled chips Base - Secure boot: Following secure configurations are supported: SBC, SLA, SDA and their combinations Base - Secure boot: Following secure configurations are NOT supported: ARB and combinations with it Base - Secure boot: Supported CPU: MT6572, MT6580, MT6582, MT6589, MT6592, MT6735, MT6752, MT6753, MT6755, MT6757, MT6763, MT6771, MT8127, MT8135, MT8167 ( list of tested ) Base - ModelBD - Manual Model DB update feature released Base - ModelBD: Allow save boot configuration in sw database for future use Base - ModelBD - Automatic Model DB update feature released Base - ModelBD: Allow save boot configuration in sw database for future use ( press and hold LCTRL key during press IDENTIFY ) Base - FlashLoader line v1904 tested and supported. Older lines (6592/6595 and similar) still unstable Base - FlashLoader line v1912 tested and supported. Older lines (6592/6595 and similar) still unstable FWFlasher: FWFlasher - Flash core updated FWFlasher - SecureFlash on Legacy phones revised FWFlasher - MT6771/6765 support revised FWReader: FWReader - More types supported for safe read FWReader - Info reading improved FWReader - packing revised FWReader - more accurate data verification Service: Service - Format FS revised Service - NVRAM module updated Platform: Platform - MT6765/MT6762 support optimized Loaders: LoaderDB - Lot of new agents included (Tecno, Tesla, Wiko and other) LoaderDB - Included MT6570 "DRAM Fixed" agents used to revive devices flashed with wrong preloader ( so called "Doogee X10 bug" ) Other: Other - Many different small changes and fixes Other - SaveUser Configuration option can be found in FILE system menu. Work only in MANUAL mode ! Other - ErrorHandling updated - more detailed hints/explanation of troubles during service process Other - Preloader tools, Preloader init and other related stuff updated Other - Partial LEGACY NAND support - optimized boot. Identify work complete if BMT autoset work correct Info: Automatic Boot option can be switched off/on in settings menu Info: Automatic Boot work in "SelfLearning" mode - once learned it will boot this type/device line after automatically Info: Automatic Boot option support and learn different modes ! Make sure if device used DIFFERENT settings - learn all of them ! Info: MT6570 Fixed NAND DA can be used for flashing FACTORY firmware and INIT PRELOADER. For FW read and all other things - use INFINITY ones ! How to use AutomaticBoot select, User DB, Auto DB Download link #1 Download link #2 Download link #3 Download link #4 - How to upload files to support Infinity-Box 14 years (2005 - 2019) updates and support as nobody else ! Last edited by InfinityHelp; 04-30-2019 at 11:21. |
The Following 91 Users Say Thank You to InfinityHelp For This Useful Post: |
04-28-2019, 23:02 | #2 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | ''Mobicel Pure Mini'' Privacy Protection Lock Remove by Single Click, thanks to Infinity Box Team & Specially ''SIR'' JayDi. Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM63) MODE : PRELOADER PORT PORT : 63 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017041453445E1010134D5A4B4D1 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 7001004545344541340101E1D1B4A4D5 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EE4EA4 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE2000000 [ 3.53 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2A0F06FDE4DB5B5CA5008F4F71D46A98 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following 7 Users Say Thank You to ...::S.L.S::... For This Useful Post: |
04-28-2019, 23:18 | #3 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | Oppo F5 when i flash Imie null....need nvram Created by Infinity-Box (c) 2019 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Device BDL [ARB] : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] Patch Level : N6F26Q Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2017-10-05 Build Time : 1510852702 Product Manfct : OPPO Board Platform : mt6763 Product Model : OPPO CPH1723 Product Brand : OPPO Product Name : CPH1723 Product Device : M6763A Product Board : full_oppo6763_17031 Product Info : oppo6763_17031 SW Version : A.07 SW OTA Version : M6763A_11.A.07_0070_201711162246 SW OTA Name : CPH1723EX_11_A.07_171116 Display ID : CPH1723EX_11_A.07_171116 Kernel Info : 4.4.22-G201711162246 Preloader [HW DEV] Info : EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] Operation : Write Flash [ v2.05 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :16 [FL] : Set : preloader_oppo6763_17031.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : tinysys-sspm.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xF21C0348 [ 3.78 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM86) MODE : BOOTROM PORT : 86 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 51378324FF21D18265EBB6DEBB2129A44381449AF3A096C4B6 F00A981FF561CA BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100524836344D42053BF56A5834BD EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C1650F794D8AF940ACB2B50BF02EB93E DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) OK SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002188000 Erase : 0x0000000004688000 : 0x0000000001500000 Erase : 0x0000000007B88000 : 0x0000000006000000 Erase : 0x000000000F000000 : 0x0000000000800000 Erase : 0x0000000012800000 : 0x0000000000200000 Erase : 0x0000000012D00000 : 0x0000000007300000 Erase : 0x000000001E000000 : 0x0000000003400000 Erase : 0x0000000021800000 : 0x0000000158000000 Erase : 0x000000017A000000 : 0x0000000D147FBE00 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : SPMFW Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : False (RAPHAEL) OK SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:30 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Dzomega For This Useful Post: |
04-29-2019, 00:28 | #5 (permalink) |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | Very sensible update.....................................thanks for wonderful work. Pls we expect more like spd etc i now know that you are working tirelessly to met up our demand. Thank...................thank............ |
The Following 2 Users Say Thank You to Oyetunde Semiu For This Useful Post: |
04-29-2019, 04:16 | #6 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Egypt Age: 37
Member: 710690 Status: Offline Thanks Meter: 907 | good work infinity team, but i have small problem when i press identify or flash, ETC SW GUI lag or stuck something like that for 5s not like old ver 1.58 speed work!! just wondering maybe i have problem and you can help me to fix it!! |
04-29-2019, 05:40 | #7 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 232 | wow excellent update new way plz update qulcomm (oppo a3s . mi -6a mtk ) |
The Following 4 Users Say Thank You to parmodparmod For This Useful Post: |
04-29-2019, 07:15 | #9 (permalink) |
Product Supporter Join Date: Apr 2016 Location: India
Member: 2562751 Status: Offline Thanks Meter: 60 | Good Update Team....Please Focus On SPD Cpu 8.1 or Higher Version . Read Write .FRP. PIN Pattern |
The Following 2 Users Say Thank You to Sourovgsm For This Useful Post: |
04-29-2019, 07:57 | #10 (permalink) |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | AutomaticBoot selection More Easy Than Previous Version... Thanks To Infinity Team |
The Following User Says Thank You to tapas770 For This Useful Post: |
04-29-2019, 09:05 | #11 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Very Great Work Infinity Team. Very Usefull Update ... |
The Following User Says Thank You to ahmer5050 For This Useful Post: |
04-29-2019, 09:20 | #13 (permalink) |
Freak Poster Join Date: Jun 2011 Location: jahanian punjab pakistan
Member: 1588653 Status: Offline Sonork: imran_Gill Thanks Meter: 83 | infinty team is always good work very usefull update |
The Following User Says Thank You to akash48 For This Useful Post: |
04-29-2019, 09:22 | #14 (permalink) |
Member: 1588653 Status: Offline Sonork: imran_Gill Thanks Meter: 83 | infinty team always Good work thanks to jaydi sir very usefull update |
