05-21-2020, 12:35 | #76 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Chinese Miracle-2 MTK/Mediatek v2.10 - usb drivers compatibility issue Software compatibility issue has been detected, it's a software conflict with some kind of usb drivers. As a result users may expeience problem like dongle misconfiguration with error code 70 and similar. CM2MT2 v2.10 has been removed from support area, new version with improved compatibility should be released in nearest time. If you have a described issue: - post your dongle details - attach fault.bin file, it's located at /CM2MT2/ folder Supporters will check the problem reason and you will get a solution ========================= see post #1 for more information Last edited by InfinityHelp; 05-21-2020 at 12:58. |
05-21-2020, 13:00 | #82 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
05-21-2020, 13:19 | #88 (permalink) |
Junior Member Join Date: May 2009 Location: INDONESIA
Member: 1039156 Status: Offline Thanks Meter: 6 | please help == DongleManager [Infinity] v1.80 [5/21/2020 19:18:19] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000120A713E64082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 885620A7 Firmware version: 0137.02 "UK Edition" status: On Last launched Application: 0030 v.0158 => Activations: - 00: Infinity-Box/Dongle v0137 - 07: #7 => Options: - Infinity-Box/Dongle - Infinity SM |
05-21-2020, 13:25 | #89 (permalink) |
Freak Poster Join Date: Aug 2011 Location: pretoria
Member: 1636627 Status: Offline Thanks Meter: 24 | Load IDBase v518137 Ok! Operation : Identify [ v2.10 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1952 | Manual : Disabled BROM : SOCID : 1CBF2E67D3120A42541DC32F7AD68F9037F28CF529BF4E64D9 D97AF2E0CA97B2 BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! this is software log sir |
05-21-2020, 14:18 | #90 (permalink) | |
It looks like your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ | |
