Old 05-20-2020, 12:22   #1 (permalink)
Member: 1043909
Thanks Meter: 53,207
Infinity Chinese Miracle-2 MTK/Mediatek v2.10 - New MTK chips and UFS storage
=== update 21-May-2020 ===
Infinity Chinese Miracle-2 MTK/Mediatek v2.10 - usb drivers compatibility issue
How to use CM2MT2 v2.10 safely:
- Wait and install CM2MT2 v2.11 in a short time or make the next right now:
- Find and delete the next applications:
  • c:\program files (x86)\intel\bluetooth\devmonsrv.exe
  • c:\program files (x86)\intel\intel(r) usb 3.0 extensible host controller driver\application\iusb3mon.exe
  • c:\program files (x86)\nec electronics\usb 3.0 host controller driver\application\nusb3mon.exe
  • c:\program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe
- Reboot PC
- Run CM2MT2 v2.10
What is the issue ?
Software compatibility issue has been detected, it's a software conflict with some kind of usb drivers.
As a result users may expeience problem like dongle misconfiguration with error code 70 and similar.
New CM2MT2 version with improved compatibility should be released in nearest time.
What to do in case of dongle misconfiguration error code 70:
- Write here your dongle details - S/N or HWID
- Attach fault.bin file, it's located at C:/InfinityBox/CM2MT2/ folder
- Wait for instruction
As ordinary, unique functions and methods released
Core
NewChip: Helio G90T (Formely MT6785) supported (UFS / eMMC)
NewChip: MT6731 supported (eMMC / NAND)
NewChip: Helio A20 (Formely MT6761 low-cost revision) supported
NewChip: Helio P90 (Formely MT6779) support under test (UFS / eMMC)
BugFix : MT6595/MT6597 BROM support broken, fixed (Agent 17xx-19xx)
New Feature : UFS FlashIC support
!* Support flashing Factory / Infinity FW
!* Support MemoryTool
!* Support Factory Firmware reading
!* Support Service operations
!* SOC's on market, support UFS chips right now : G90, P70, P90
Service
Changed : Repair security procedure updated (Flash and Meta mode)
Changed : SPUnlock procedure updated (Flash and Meta mode)
Changed : Identify procedure updated
Changed : Format FS / Reset FRP now support UFS flash too
New Feature : Modem Re-Init (NVfix)
!* Useful after FixBB, in case of modem subsystem alive
Firmware Reader
New Feature : UFS flash support
New Feature : Combo scatter creation for newest chipset
!* Produced scatter MAY NOT work with OLDER SPFT (factory flasher) below 19xx versions!
!* Produced scatter is 100% like factory ones
Changed : Improved structure identification
Changed : Support more different types
Changed : NAND support revised
Changed : LEGACY line support revised
Changed : Platform and version depend scatter creation for better compatibility with SPFT
Changed : LEGACY line with Android 9 (MT6580 and similar) specific changes
MemoryTool
!* Support Read , Write , Erase partitions
!* Support RePartition
!* Support Preloader init
!* Support Change Work mode (ADR / PRT)
!* Change storage settings useless, all flash content mapped in single mode
Changed : Structure identification
Changed : Automatic files selection at folder change
Flasher
New Feature : Support COMBO scatter's (v2.xxx)
!* Automatic selection depend on device Flash (UFS/EMMC/NAND)
!* Storage selection done automatic according detected, for end-user all selection and rest settings remain same as before
New Feature : Support MTK chips with UFS FlashIC flashing
!* All features (Erase / Verify / PMT upgrade / Backup / HW Compatibility) work for devices with UFS as well
Changed : Scatter tab changes, specific to multi-storage selection and settings
Meta protocol functions updated
Changed : Updated security detection feature
BugFix : Updated structure verification
Other
BugFix : A lot of minor changes and bugfixes applied
Changed: Many internal changes to improve compatibility with other applications, antiviruses and similar software.
Changed: Software load/operation speed improvements implemented
Password for files: 12345678
Download link #1
Download link #2
Download link #3
Information about Infinity products support period renew due to situation with COVID-19
- How to upload files to support
Infinity-Box 15 years (since year 2005) updates and support as nobody else !
The Following 67 Users Say Thank You to YellowBoss For This Useful Post:
Old 05-20-2020, 12:29   #2 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 587
Very VERY good Work Infinity Team..
The Following User Says Thank You to ahmer5050 For This Useful Post:
Old 05-20-2020, 12:34   #3 (permalink)
Crazy Poster
Member: 2075865
Thanks Meter: 9
superd!!!! . the best team on gsm market
Old 05-20-2020, 12:56   #4 (permalink)
Crazy Poster
Member: 2937153
Thanks Meter: 9
Core
Service
Firmware Reader
MemoryTool
Flasher
Other
Download link #1
Download link #2
Download link #3
Amazing work team.
We are waiting for qlm/best 2 update.
Keep with the great work.
The Following User Says Thank You to y8765 For This Useful Post:
Old 05-20-2020, 13:46   #5 (permalink)
melmitador's Avatar
Member: 1544111
Sonork: 100.1611711
Thanks Meter: 60
need support oppo and relme for flashing without tp
Old 05-20-2020, 13:53   #6 (permalink)
Member: 2708690
Thanks Meter: 6
Niceeeeeeeeeeee work
Old 05-20-2020, 13:54   #7 (permalink)
Member: 2812901
Thanks Meter: 413
Best team keep it up ...................................
Old 05-20-2020, 13:58   #8 (permalink)
Member: 2812901
Thanks Meter: 413
To used this 2.10 what version of dongle required
Core
Service
Firmware Reader
MemoryTool
Flasher
Other
Download link #1
Download link #2
Download link #3
Old 05-20-2020, 14:22   #9 (permalink)
Member: 2500215
Thanks Meter: 246
Work on Qualcomm module that was last updated in the 80s...
The Following 4 Users Say Thank You to Southsider2009 For This Useful Post:
Old 05-20-2020, 14:57   #10 (permalink)
Member: 220595
Thanks Meter: 268
Which card firmware is required?
Enviado desde mi SM-G975U1 mediante Tapatalk
Old 05-20-2020, 15:02   #11 (permalink)
Member: 818995
Thanks Meter: 19
I am falling in love with infinity Boom Boom Ufs supported tool.
Old 05-20-2020, 15:07   #12 (permalink)
Member: 220595
Thanks Meter: 268
You are late to the wedd1ng then...
We have been in love for many many years...
The Following User Says Thank You to yurais For This Useful Post:
Old 05-20-2020, 15:35   #13 (permalink)
Member: 818995
Thanks Meter: 19
Hello Bro i just created a account in earlier 2008. but i haven't start work in this field from 2008. i just started to work in gsm field around a year ago. so i just realized about Infinity team.
Old 05-20-2020, 15:49   #14 (permalink)
Member: 220595
Thanks Meter: 268
Welcome abroad , start proof it...
Old 05-20-2020, 15:50   #15 (permalink)
Member: 2048880
Thanks Meter: 57
smart card misconfiguration
smart card misconfiguration contact to support
plz help me
after update MTK/Mediatek v2.10 and update dongle whit dongle manager 1.80 to 143
The Following 2 Users Say Thank You to rezakeshavarza For This Useful Post:
Page generated in 0.20986 seconds with 7 queries
