05-24-2020, 11:14 | #46 (permalink) | |
Fix PC as per instruction - https://www.infinity-box.com/news/?r=3999 or use CM2MT2 v2.11 After that update dongle firmware with DongleManager to fix "misconfiguration" message | |
05-24-2020, 11:21 | #47 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Help i cant update my dongle Code: === DongleManager [Infinity] v1.80 [24-05-2020 15.47.04] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: 01018C6720281292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): CE618C67 Firmware version: 0140.02 === Process started: 24-05-2020 15.47.05 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! Code: Serial Number: CE618C67 Username: 00CE618C67 Token Type: Infinity-Box/Dongle Registered: 2015-06-05 Expired: 2022-01-31 Account Status: Active Firmware Version: 0143 Hardware Status: Ok |
05-24-2020, 11:39 | #48 (permalink) | |
Update it once again now. Result ? | |
05-24-2020, 12:34 | #50 (permalink) |
Insane Poster Join Date: May 2015
Member: 2393670 Status: Offline Thanks Meter: 14 | Yelow boss ,answer please!! Always waiting your answer Can i repair unknow baseband and repair imei on tecno spark 4 kc8 mt6761 i already write nvram from a good phone, writing done but phone still same problème i already repair unknow baseband ,done but same problèm i already flash phone ,done but same problèm What the solution please ? Report Post |
05-24-2020, 13:40 | #52 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
If you want to get an answer about your specific phone I suggest you create separate thread and provie full information with operation logs etc. P.S. Your spam posts will be removed in short tim as soon I will find a time to clean this nice forum from spam Thank you for your kind understanding ! | |
05-24-2020, 15:26 | #54 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
There is no need special tool, just engenier fw or modem/parts from it to acvhieve a result. | |
05-24-2020, 15:27 | #55 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Words is dust. Post logs. I sure at 146% about you have select wrong generation or revision of CPU in list. But, anyway, we should check and make sure about there is no issues at SW side. |
05-24-2020, 15:28 | #56 (permalink) | |
05-24-2020, 15:29 | #57 (permalink) | |
05-24-2020, 15:32 | #58 (permalink) | |
In one of next updates it will be activated and explained. | |
05-24-2020, 15:33 | #59 (permalink) | |
Make just a mp3 player from a phone - bad idea. Use only SW for Nokia phones. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
