Old 05-23-2020, 20:32   #31 (permalink)
Member: 2046063
Sonork: 19
Thanks Meter: 2
Thanks for that update v2.11 but when a u updating qualicim tool.
The Following User Says Thank You to freddiek For This Useful Post:
Old 05-23-2020, 20:34   #32 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 151
team pls add huawei new mtk models flash, repair
(dra-lx5 phone i have at the moment in my hand baseband unknown was flash using sd card succefully but still base band unknown.)
if need test can contact whatsapp +94755853893.
Old 05-23-2020, 23:25   #33 (permalink)
Member: 2150890
Thanks Meter: 3
Thanks for the update, but you can select the cm2mt2 app and open it without activation and select the new version.
Old 05-24-2020, 00:45   #34 (permalink)
Member: 1043909
Thanks Meter: 53,210
as soosn as I will have more time for the work
Old 05-24-2020, 00:46   #35 (permalink)
Member: 1043909
Sorry, I do not understad the problem well. Please explain
Old 05-24-2020, 02:36   #36 (permalink)
aymandh4's Avatar
Member: 2529545
Thanks Meter: 55
Thanks for update v2.11
This version fix error not supported read Firmware secure boot ? ?
Like new nokia 1 plus ..
Or old model huawei TIT-AL00 ..
Envoyé de mon SM-J600F en utilisant Tapatalk
Old 05-24-2020, 02:42   #37 (permalink)
Member: 2554825
CM2QLM not working
auto fault bin created
Old 05-24-2020, 03:22   #38 (permalink)
Member: 2801682
Thanks Meter: 2
Hello sir please update Qualcomm modules
The Following User Says Thank You to allss For This Useful Post:
Old 05-24-2020, 06:29   #39 (permalink)
Member: 1659029
Thanks infinity
Good update
Old 05-24-2020, 09:25   #40 (permalink)
Member: 2225310
Sonork: 4514541151541
=== DongleManager [Infinity] v1.80 [5/24/2020 14:15:39] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 0000B724217A4082
Box/Dongle found: Infinity-Box/Dongle
Serial No (S/N): 1DE1B724
Firmware version: 0143.02
Box/Dongle misconfiguration
Diagnostic code: 70
"UK Edition" status: Off
Last launched Application: 0030 v.0143
=> Activations:
- 00: Infinity-Box/Dongle v0143
=> Options:
- Infinity-Box/Dongle
Old 05-24-2020, 09:58   #41 (permalink)
Member: 1043909
Hi,
Need to try each model and see results.
In case of problem copy/paste software operation log text, team always check reports and see how is process going.
Old 05-24-2020, 09:59   #42 (permalink)
Member: 1043909
Hello,
It means some kind of non-fatal software conflict take place.
Attach fault.bin file here, we will check it and tell you what to do.
also do not forget to disable AVAST if you have it running.
Old 05-24-2020, 10:01   #43 (permalink)
Member: 1043909
Thank you very much for your kind advice ! Team will try to follow your reqest !
Old 05-24-2020, 10:30   #44 (permalink)
gsmTECHNICIAN's Avatar
Member: 922938
Thanks Meter: 56
When I extract that software always error 99% I off the antivirus update WinRAR restart pc what was the problem I don't get it please I need yr support boss...
Old 05-24-2020, 11:13   #45 (permalink)
Member: 1043909
Setup file is big, you should have a lot of free space at your HDD.
Check it and try again
Result ?
Page generated in 0.18527 seconds with 7 queries
