11-04-2016, 19:29 | #108 (permalink) | ||
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan
Member: 2138570 Status: Offline Sonork: 100.1611495 Thanks Meter: 301 | qmobile z9 read firmware done Quote:
11-04-2016, 22:32 | #110 (permalink) |
No Life Poster Join Date: May 2006 Location: The_Colombian_Team !
Member: 278939 Status: Offline Sonork: 100.1593095 Thanks Meter: 382 | 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 09BDEC71 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : G630-U251 ProdModel : G630-U251 Device : hwG630-U251 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__G630-U251__hwG630-U251__G630-U251 ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-05-2016, 16:41 | #116 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Install drivers first. | |
11-06-2016, 06:26 | #117 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Quote:
11-06-2016, 06:36 | #118 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | coolpad dozen 8297-100 not supported Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0D9741A6 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 020DEB74624DF230 ID_BLOCK_L : 5EB32D15BA19C30D Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0D9741A6 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 020DEB74624DF230 ID_BLOCK_L : 5EB32D15BA19C30D Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-06-2016, 06:52 | #119 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | infocus m370 not supported Code: Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 015DFB4B ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : InFocus ProdName : FAO_00WW ProdModel : M370 Device : FAO AndroidVer: 5.1.1 Manufact. : FIH QLMxCPU : MSM8909 DevInfo : MSM8909__FIH__InFocus__ANDR_v5.1.1__M370__FAO__FAO_00WW ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 015DFB4B ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : InFocus ProdName : FAO_00WW ProdModel : M370 Device : FAO AndroidVer: 5.1.1 Manufact. : FIH QLMxCPU : MSM8909 Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
11-06-2016, 09:34 | #120 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | finaly done was driver not install here log Card found : S/N : D76D8172 , v0134 Infinity-Box Qualcomm Module [QLM] v 1.01 Operation : Reset Settings [ v1.01 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 03590CEF ID_BLOCK_I : 009600E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:13 Reconnect Power/Cable! Last edited by CHAUDHRAY ARSHAD; 11-06-2016 at 09:42. |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
