01-14-2017, 10:28 | #65 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | THINKS infinity team but about a SmartAV i know its very hard to add but can you add featers for unpack repack system.img for analyse my antivirus soft and repack it to flash its manual scan clean virus |
01-14-2017, 11:53 | #67 (permalink) | |
Freak Poster Join Date: Dec 2008
Member: 915829 Status: Offline Thanks Meter: 29 | Quote:
The Following User Says Thank You to a.gani For This Useful Post: |
01-14-2017, 12:10 | #68 (permalink) | |||
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Another improvement maybe. Currently when loading firmware from .xml software will sometimes say that the firmware is invalid, but doesn't mention how or in which line. For example, i had Xiaomi Kate with EDL mode only. Found firmware for it but when loading to Infinity is says: Quote:
In general, a bit more detailed error messages would be nice and helpfull, in case someone wants to make own flashable image or fix the broken ones. | |||
01-14-2017, 12:25 | #69 (permalink) | |
Member: 25996 Status: Offline Thanks Meter: 253 | Lumia 635, RM-974. Enters EDL mode with EDL cable easy. Plan was to dump userdata since phone is stucked on Windows logo. Quote:
01-14-2017, 12:35 | #70 (permalink) |
Registered User Join Date: Dec 2015 Location: Chittagong, Bangladesh
Member: 2506300 Status: Offline Thanks Meter: 345 | CM2 is King........... Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 03F8BADA ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 743DAE8C3037F9BCD5AF396CE052AAAD ID_BLOCK_L : C03C36ED200B1BD38C1FB4AFC83EEADF Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G34 Boot Ok! Brand : Xiaomi ProdName : kate ProdModel : Redmi Note 3 Device : kate AndroidVer: 6.0.1 Manufact. : Xiaomi QLMxCPU : MSM8952 DevInfo : MSM8952__Xiaomi__Xiaomi__ANDR_v6.0.1__Redmi_Note_3 __kate__kate Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : splash.img [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : mdtp.img [Read Ok] : cust.img [Read Ok] : cmnlib.mbn [Read Ok] : keymaster.mbn [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8976 / eMMC Firmware Size : 3494 MiB Done! Elapsed: 00:06:51 Reconnect Power/Cable! |
01-14-2017, 12:41 | #71 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Infront Of My Laptop Age: 34
Member: 799558 Status: Offline Thanks Meter: 430 | Code: Xiaomi Redmi Note 3 Read Flash With working Phone But Error Massage Has Came Code: Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 0236D793 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 8BF45773F9C830631266F2B52995656A ID_BLOCK_L : FEFE74D3E235DD0DCA5D76710E78A419 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Brand : Xiaomi ProdName : kenzo ProdModel : Redmi Note 3 Device : kenzo AndroidVer: 5.1.1 Manufact. : Xiaomi QLMxCPU : MSM8952 DevInfo : MSM8952__Xiaomi__Xiaomi__ANDR_v5.1.1__Redmi_Note_3__kenzo__kenzo Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : splash.img [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : mdtp.img [Read Ok] : cust.img Error : Failed to convert data! Erased/Damaged device??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
01-14-2017, 14:11 | #72 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2672131 Status: Offline Thanks Meter: 16 | Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 16757611 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 966E04F25DC9F6F1AE834D529DE46C5C ID_BLOCK_L : 2C27E94035DC0E873AF5DE171D908ECD Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following User Says Thank You to EMMC_KILLER For This Useful Post: |
01-14-2017, 15:19 | #74 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
They close ALL, what possible. Reading is rejected on FAST/FH. But have some stuff for near 10 models. Later will make. | |
