02-19-2017, 12:37 | #226 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
02-19-2017, 12:39 | #227 (permalink) | |
Then upgrade over WiFi. | |
02-20-2017, 05:05 | #229 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | Huawei S7-721U Not Supported Code: Huawei MediaPad 7 Youth 2 S7-721u Tablet PC Specifications Type Tablet Form Factor Candybar Network 2G: GSM 850 / 900 / 1800 / 1900 MHz 3G: UMTS 850 / 900 / 1900 / 2100 MHz Display 7.0-inch 600 x 1024 pixels 169.4 ppi pixel density 16M colors Capacitive multit-touch (up to 5 fingers) Processor Qualcomm Snapdragon 200 MSM8212 chipset Quad-core 1.2 GHz ARM Cortex-A7 CPU Adreno 130 GPU RAM & Storage 1 GB LPDDR2 SDRAM 4 GB built-in storage microSD slot, supports up to 32 GB Operating System Android 4.3 (Jelly Bean) with Huawei Emotion UI 1.6 Camera 3.2 MP (2048 x 1536 pixels) rear camera HD (1280 x 720 pixels) video recording @ 30fps 0.3 MP (640 x 480 pixels) front-facing camera Data/Connectivity GPRS Class 12, EDGE, UMTS, HSDPA, HSUPA 5.76 Mbps, HSPA+ 21 Mbps Bluetooth 3.0 with A2DP Wi-Fi 802.11b/g/n microUSB 2.0 DLNA Battery Lithium-polymer 4100 mAh Dimensions and Weight 120.6 x 193.4 x 9.9 mm 350 grams Features 3.5mm audio jack Accelerometer Light sensor Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 04AFB11B ID_BLOCK_I : 008140E1 ID_BLOCK_L : A85832CC6BF7FCEFD88D474897D2626A ID_BLOCK_L : 6A19A7060B9AC44144B3E4DDD7DEC8F3 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : msm8610 ProdModel : msm8610 Device : msm8610 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__msm8610__msm86 10__msm8610 ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Send report to mail : [email protected] with title "QFW" ! Info : Device is not supported yet! Send log and report.log to support! Include device info also! |
02-21-2017, 08:39 | #230 (permalink) |
Member: 2604648 Status: Offline Thanks Meter: 346 | HUAWEI Y530-U00 MSM8610 Read FW Done Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 0164C329 ID_BLOCK_I : 008110E1 ID_BLOCK_L : BE463CDA75E1EE19C6BB55BA85DC5474 ID_BLOCK_L : 3F56F85344CF7FF409E4A9666C839DBE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : Y530-U00 ProdModel : HUAWEI Y530-U00 Device : hwY530-U00 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__HUAWEI_Y530-U00__hwY530-U00__Y530-U00 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : oemdata.bin [Read Ok] : NON-HLOS.bin [Read Ok] : fs_gc.img [Read Ok] : persist.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cust.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 1373 MiB Done! |
The Following User Says Thank You to buffer2k11 For This Useful Post: |
02-21-2017, 11:49 | #231 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 497508 Status: Offline Thanks Meter: 23 | lenovo tab yoga 850m reset frp done BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 0092F802 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 87611BE352D8C5C0BF947C61AEF57D4D ID_BLOCK_L : 49048A2516B921A22796FB3032FDEBD0 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Remove FRP ( Google Reset Protection ) FRP removed! Reset Ok! |
02-21-2017, 18:44 | #232 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 47
Member: 205157 Status: Offline Sonork: 100.1574537 Thanks Meter: 82 | OPPO A37f ReadInfo & Format Done Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1B11F8B1 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 36CEA452FD6996914E232D32FD44CCFC ID_BLOCK_L : C8BB05A4A938A223A6117AB3B17C6A51 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1B11F8B1 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 36CEA452FD6996914E232D32FD44CCFC ID_BLOCK_L : C8BB05A4A938A223A6117AB3B17C6A51 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! |
02-21-2017, 21:27 | #233 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Cuba Age: 36
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | Failed to read or wirte LG H811 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.10 Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 808 [MSM8992] ID_BLOCK_S : 005A3B9D ID_BLOCK_I : 009690E1 ID_BLOCK_E : 005A3B9D ID_BLOCK_L : 5351297FB10AF0DB79F155116D419E1D ID_BLOCK_L : 776AC1F00205A2E9053C962B01590344 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
02-22-2017, 05:03 | #234 (permalink) | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
02-23-2017, 00:50 | #236 (permalink) |
Junior Member Join Date: Mar 2007 Location: cavite
Member: 478013 Status: Offline Thanks Meter: 7 | pls add Mi 5s msm8996 cpu Operation : Reset UserLocks [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 17CFADD0 ID_BLOCK_I : 0005F0E1 ID_BLOCK_L : 2C4351E00CE78486E254DF2FE2C933D9 ID_BLOCK_L : 2D59EE8B44FB298F274E5913F29BAD68 Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
02-23-2017, 17:41 | #237 (permalink) |
Member: 205157 Status: Offline Sonork: 100.1574537 Thanks Meter: 82 | OPPO 3006, Read Info, Read Pattern W/O DataLoss, Reset UserLocks, Read Flash Done Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0587AB67 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7C84FE18B723285B04799B84431E96B6 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : 3006 ProdModel : 3006 Device : 3006 AndroidVer: 4.4.4 Manufact. : OPPO QLMxCPU : MSM8916 Done! Elapsed: 00:00:08 Operation : Read PatternLock [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0587AB67 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7C84FE18B723285B04799B84431E96B6 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 12357 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0587AB67 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7C84FE18B723285B04799B84431E96B6 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : 3006 ProdModel : 3006 Device : 3006 AndroidVer: 4.4.4 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v4.4.4__3006__3006__3006 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : misc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : driver.iso [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 1492 MiB Done! Elapsed: 00:03:06 Reconnect Power/Cable! Operation : Reset UserLocks [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0587AB67 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7C84FE18B723285B04799B84431E96B6 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Direct access : Ok! Processing step #1 Processing step #2 Processing step #3 Processing step #4 Processing step #5 Processing step #6 Processing step #7 UserLocks reset passed! 1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart! 2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints 3. In some cases require reboot phone twice or wait up to 5 minutes! Done! Elapsed: 00:00:54 Reconnect Power/Cable! |
The Following User Says Thank You to cellncare For This Useful Post: |
02-24-2017, 12:42 | #238 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1972952 Status: Offline Thanks Meter: 4 | infinity team i request plz more feature add next update 1 endble qualcomm diag 2 read nv 3 write nv 4 boot edl mode 5 qcn read 6 qcn write 7 qualcomm imei repair 8 spd 6820/8810 9 spd 6825/8825 Last edited by naveen14; 02-24-2017 at 12:49. |
