Old 05-13-2017, 06:27   #241 (permalink)
buffer2k11's Avatar
Member: 2604648
Thanks Meter: 346
Originally Posted by JayDi View Post
UFS + MSM8996
Operation : Read Flash [ v1.12 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 820 [MSM8996]
ID_BLOCK_S : B861DCBB
ID_BLOCK_I : 009470E1
ID_BLOCK_E : 2A703DB9
ID_BLOCK_L : C4CF6F2386EC1D32B0AF58AB5E37F2A3
ID_BLOCK_L : 527BBE85A099E0CC4DA13129613BB67A
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1
ExtInfo : 0x0000C000/0000C000/00001000/00001000
Boot Ok!
Brand     : OnePlus
Device    : OnePlus3
AndroidVer: 7.1.1
SWVersion : OnePlus3Oxygen_16.A.51_GLO_051_1704112009
Manufact. : OnePlus
QLMxCPU   : MSM8996
DevInfo : MSM8996__OnePlus__OnePlus__ANDR_v7.1.1__OnePlus3__OnePlus3Oxygen_16.A.51_GLO_051_1704112009
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : persist.img
[Read Ok] : cache.img
[Read Ok] : misc.img
[Read Ok] : devcfg.mbn
[Read Ok] : pnvbak.img
[Read Ok] : param.cfg
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
[Read Ok] : gpt_main1.bin
[Read Ok] : xbl.bin
[Read Ok] : gpt_backup1.bin
[Read Ok] : gpt_main2.bin
[Read Ok] : gpt_backup2.bin
[Read Ok] : gpt_main3.bin
[Read Ok] : ddr.bin
[Read Ok] : gpt_backup3.bin
[Read Ok] : gpt_main4.bin
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : hyp.mbn
[Read Ok] : sec.dat
[Read Ok] : pmic.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : adspso.bin
[Read Ok] : mdtp.img
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : lsplash.img
[Read Ok] : boot.img
[Read Ok] : boot_ag.img
[Read Ok] : system.img
[Read Ok] : recovery.img
[Read Ok] : btfm.mbn
[Read Ok] : keymaster.mbn
[Read Ok] : cmnlib.mbn
[Read Ok] : cmnlib64.mbn
[Read Ok] : ap.mbn
[Read Ok] : gpt_backup4.bin
[Read Ok] : gpt_main5.bin
[Read Ok] : md5.img
[Read Ok] : gpt_backup5.bin
Android Info saved!
Read finished!
Configuration : MSM8996 / UFS
Firmware Size : 2867 MiB
Done!
Elapsed: 00:03:17
wow waiting for new update sir jaydi and infinity team
Old 05-13-2017, 08:48   #242 (permalink)
jawed_ali's Avatar
Member: 724704
Sonork: 100.1605390
Thanks Meter: 92
i have mi not3 2015116 its a pin lock andriod os 6.0.1 i try to cm2 qlm but nothing be done i have try to new update but nothing can u help me infinyty team i just need reset my pin lock only
Old 05-13-2017, 10:19   #243 (permalink)
Member: 1370448
wat u mean Close all sniff/share/monitor sw and start CM2QLM
Old 05-13-2017, 10:53   #244 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Post logs for start.
If there is encrypted FS ( sw will warn about it ) - there is no way, except reset.
Old 05-13-2017, 10:59   #245 (permalink)
JayDi's Avatar
Member: 462970
- Uninstall and do not use any kind of usb-sharing or port sniff software during your work to avoid software conflicts and possible software incompatibility !
Old 05-13-2017, 11:43   #246 (permalink)
Member: 1370448
i already remove fault.bin but same error
Old 05-13-2017, 11:46   #247 (permalink)
Member: 1370448
remove fault.bin uninstall and install pc not connect other software
except infinity dongle
Old 05-13-2017, 12:30   #248 (permalink)
JayDi's Avatar
Member: 462970
Send fault on support email and wait for instructions in answer.
Old 05-15-2017, 08:18   #249 (permalink)
buffer2k11's Avatar
Member: 2604648
Thanks Meter: 346
CM Superion Probe MSM8610 Read FW
Operation : Read Flash [ v1.11 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12]
ID_BLOCK_S : 034ECAFC
ID_BLOCK_I : 008140E1
ID_BLOCK_L : 897B11ED48D6C3CEB9EE666FA8F3034B
ID_BLOCK_L : 0578C6696AF565EEE3D2877C76B9B794
Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1
Boot Ok!
Brand : qcom
ProdName : fw8977
ProdModel : A680
Device : msm8610
AndroidVer: 4.3
Manufact. : unknown
QLMxCPU : MSM8610
DevInfo : MSM8610__unknown__qcom__ANDR_v4.3__A680__msm8610__ fw8977
[Read Ok] : sbl1.mbn
[Read Ok] : deploy.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : splash.img
Android Info saved!
Read finished!
Configuration : MSM8x10 / eMMC
Firmware Size : 610 MiB
Done!
Elapsed: 00:01:52
The Following User Says Thank You to buffer2k11 For This Useful Post:
Old 05-15-2017, 08:57   #250 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
Vsun Smart Process Flush done
Operation : Flash [ v1.26 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 35 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.09_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Erase Block : INTERNALSD
Erase block ...
Block erase Ok!
Elapsed: 00:04:44
Reconnect Power/Cable!
The Following User Says Thank You to nahidroman For This Useful Post:
Old 05-15-2017, 14:23   #251 (permalink)
mojahiudul's Avatar
Member: 1393008
Sonork: C0821FB9
Thanks Meter: 47
Read and Formate done thanks Team: Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : Xiaomi
Device Manufact.: Xiaomi
Device Model : rolex
Device CPU : MSM8937
Device IntName : rolex
Device Version : 6.0.1
CU_SWVer : Xiaomi
Device Compile : 12/8/2016 11:02:13 AM
Device ExtInfo : Redmi 4A
The Following User Says Thank You to mojahiudul For This Useful Post:
Old 05-16-2017, 16:24   #252 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
oppo f1w flash fail umt flash done need cm2qlm modul update
loading firmware ...
Created by infinity-box (c) chinese miracle ii (c) 2017
device brand : Oppo
device manufact.: Oppo
device model : F1f
device cpu : Msm8916
device intname : F1f
device version : 5.1.1
cu_swver : Oppo
device compile : 3/27/2017 4:19:36 am
device extinfo : F1f
load ok!
Operation : Flash [ v1.11 ]
forceflashing : Disabled
verify fw package ...
Verification passed!
1. Power off phone , remove battery , insert back
2. Press and hold both volume keys!
3. Insert usb cable. In some cases require use edl cable or tp to force edl mode!
Wait for phone...
Device not found!
Check cable, connection and drivers!
Reconnect power/cable!
Wait for phone...
Device found!
Initialize ...
Handshake passed!
Bb_idc_cpu : Snapdragon 610 [msm8936]
id_block_s : 06f5ff12
id_block_i : 0090b0e1
id_block_l : 97510bf362c8f5f0af844c519ee56d5d
id_block_l : Aca769c0b55c8e07ba755e979d100e4d
pickup loader from firmware package
loader sent! Initializing ...
Running firehose on bbid : Msm8936 , flash : Emmc , mver : 1
meminfo : 0x0003 / 0x0200 / 0x00000003a3e00000 [ emmc 16 gib ]
extinfo : 0x00004000/00004000/00001000/00001000
boot ok!
Files in chain : 33
flashing now
flashing : Gpt_main0.bin
flashing : Non-hlos.bin
flashing : Sec.dat
flashing : Sbl1.mbn
flashing : Sbl1.mbn
flashing : Emmc_appsboot.mbn
flashing : Rpm.mbn
flashing : Rpm.mbn
flashing : Tz.mbn
flashing : Tz.mbn
flashing : Hyp.mbn
flashing : Hyp.mbn
flashing : Lsplash.img
flashing : Boot.img
flashing : Recovery.img
flashing : System.img
flashing : Cache.img
flashing : Persist.img
flashing : Misc.img
flashing : Driver.iso
flashing : Userdata.img
progstart : Parsed value exceeds size of partition in sectors
flash error , no ack message! Check battery charge , cable
error : Flashing failed!
Check previous message for more info!
reconnect power/cable!
operation : Flash
checking for existing devices... Found
port : Com58
opening port... Ok
init handshake sequence... Ok
hardware id : E1b09000 [8936] 00000000
initializing protocol... Ok
using auto selection
preparing firehose loader... Done
sending loader [8936.ufl]... Done
executing loader... Ok
hardware : 8936, emmc, 16 gb
payload info : In: 262144 [4096], out: 16384, sector size: 512
writing [non-hlos.bin] -> [modem] ... Done
writing [ddr.img] -> [ddr] ... Done
writing [sec.dat] -> [sec] ... Done
writing [sbl1.mbn] -> [sbl1] ... Done
writing [sbl1.mbn] -> [sbl1bak] ... Done
writing [emmc_appsboot.mbn] -> [aboot] ... Done
writing [emmc_appsboot.mbn] -> [abootbak] ... Done
writing [rpm.mbn] -> [rpm] ... Done
writing [rpm.mbn] -> [rpmbak] ... Done
writing [tz.mbn] -> [tz] ... Done
writing [tz.mbn] -> [tzbak] ... Done
writing [hyp.mbn] -> [hyp] ... Done
writing [hyp.mbn] -> [hypbak] ... Done
[protective_flash] skipping [dynamic_nvbk.bin] -> [oppodycnvbk]
[protective_flash] skipping [static_nvbk.bin] -> [oppostanvbk]
writing [logo.bin] -> [logo] ... Done
writing [boot.img] -> [boot] ... Done
writing [recovery.img] -> [recovery] ... Done
writing [system.img] -> [system]... Done
writing [cache.img] -> [cache]... Done
writing [persist.img] -> [persist]... Done
writing [driver.iso] -> [driver] ... Done
writing [userdata.img] -> [userdata]... Done
writing [gpt_main0_partition_msm_15309.xml.bin] -> [primarygpt] ... Done
writing [gpt_backup0.bin] -> [backupgpt] ... Done
applying patches... . . . . . . . . . . . . . Done
resetting device... Done
operation finished.
Module ver. 0.9
Old 05-16-2017, 17:39   #253 (permalink)
JayDi's Avatar
Member: 462970
@nahidroman, CM2 will write factory FW ( xml+patches ) to that device without problems as well, so your comprassion si not correct.
Anyway :
Such problem happen due different FlashIC sizes on same models ( in fact just different vendors ) , when more samples will be collected - we will update automatic repart.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-16-2017, 18:45   #254 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 518
UFS + MSM8996
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Brand     : OnePlus
Device    : OnePlus3
AndroidVer: 7.1.1
Manufact. : OnePlus
QLMxCPU   : MSM8996
[Read Ok] : xbl.bin
[Read Ok] : ddr.bin
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : hyp.mbn
[Read Ok] : sec.dat
[Read Ok] : ap.mbn
[Read Ok] : md5.img
Android Info saved!
Read finished!
Done!
Elapsed: 00:03:17
@jaydi waiting .................................
Old 05-16-2017, 20:48   #255 (permalink)
Ouzigzag's Avatar
Member: 1753151
Sonork: 100.1658597
Thanks Meter: 332
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 0E448F90
ID_BLOCK_I : 007050E1
ID_BLOCK_E : 11112222
ID_BLOCK_L : 29B77EA6B39A8006702C1025D06883DC
ID_BLOCK_L : 7980E31D4109BC61867484B861658E63
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000
Boot Ok!
Brand     : asus
ProdName  : WW_Z00L
ProdModel : ASUS_Z00LD
Device    : ASUS_Z00L_63
AndroidVer: 5.0.2
Manufact. : asus
QLMxCPU   : MSM8916
DevInfo : MSM8916__asus__asus__ANDR_v5.0.2__ASUS_Z00LD__ASUS_Z00L_63__WW_Z00L
ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log
Send report to mail : [email protected] with title "QFW" !
Info  : Device is not supported yet!
Send log and report.log to support! Include device info also!
report log send to support done
Please share FW. We. Need it
Envoyé de mon MotoG3-TE en utilisant Tapatalk
The Following User Says Thank You to Ouzigzag For This Useful Post:
Page generated in 0.24160 seconds with 8 queries
