05-13-2017, 06:27 | #241 (permalink) | |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | Quote:
05-13-2017, 08:48 | #242 (permalink) |
Freak Poster Join Date: Mar 2008 Location: ANDROID HEART
Member: 724704 Status: Offline Sonork: 100.1605390 Thanks Meter: 92 | i have mi not3 2015116 its a pin lock andriod os 6.0.1 i try to cm2 qlm but nothing be done i have try to new update but nothing can u help me infinyty team i just need reset my pin lock only |
05-13-2017, 10:53 | #244 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
If there is encrypted FS ( sw will warn about it ) - there is no way, except reset. | |
05-15-2017, 08:18 | #249 (permalink) |
Member: 2604648 Status: Offline Thanks Meter: 346 | CM Superion Probe MSM8610 Read FW Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 034ECAFC ID_BLOCK_I : 008140E1 ID_BLOCK_L : 897B11ED48D6C3CEB9EE666FA8F3034B ID_BLOCK_L : 0578C6696AF565EEE3D2877C76B9B794 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : qcom ProdName : fw8977 ProdModel : A680 Device : msm8610 AndroidVer: 4.3 Manufact. : unknown QLMxCPU : MSM8610 DevInfo : MSM8610__unknown__qcom__ANDR_v4.3__A680__msm8610__ fw8977 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : boot.img [Read Ok] : tz.mbn [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 610 MiB Done! Elapsed: 00:01:52 |
The Following User Says Thank You to buffer2k11 For This Useful Post: |
05-15-2017, 08:57 | #250 (permalink) | ||
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | Vsun Smart Process Flush done Quote:
The Following User Says Thank You to nahidroman For This Useful Post: |
05-15-2017, 14:23 | #251 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Aricha Ghat, Bangladesh
Member: 1393008 Status: Offline Sonork: C0821FB9 Thanks Meter: 47 | Read and Formate done thanks Team: Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : Xiaomi Device Manufact.: Xiaomi Device Model : rolex Device CPU : MSM8937 Device IntName : rolex Device Version : 6.0.1 CU_SWVer : Xiaomi Device Compile : 12/8/2016 11:02:13 AM Device ExtInfo : Redmi 4A |
The Following User Says Thank You to mojahiudul For This Useful Post: |
05-16-2017, 16:24 | #252 (permalink) | ||
Member: 2443283 Status: Offline Thanks Meter: 518 | oppo f1w flash fail umt flash done need cm2qlm modul update Quote:
05-16-2017, 17:39 | #253 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @nahidroman, CM2 will write factory FW ( xml+patches ) to that device without problems as well, so your comprassion si not correct. Anyway : Such problem happen due different FlashIC sizes on same models ( in fact just different vendors ) , when more samples will be collected - we will update automatic repart. |
05-16-2017, 18:45 | #254 (permalink) | |
Member: 2443283 Status: Offline Thanks Meter: 518 | Quote:
05-16-2017, 20:48 | #255 (permalink) | |
Freak Poster Join Date: Apr 2012 Location: World Age: 37
Member: 1753151 Status: Offline Sonork: 100.1658597 Thanks Meter: 332 | Quote:
Envoyé de mon MotoG3-TE en utilisant Tapatalk | |
The Following User Says Thank You to Ouzigzag For This Useful Post: |
