03-16-2017, 06:21 | #17 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Do you have any plans to add FRP removal of motorola Infinty Team ?????????????????? |
The Following 2 Users Say Thank You to ahmer5050 For This Useful Post: |
03-16-2017, 07:07 | #20 (permalink) |
Freak Poster Join Date: Mar 2014 Location: wazirabad gujranwala pakistan Age: 30
Member: 2158722 Status: Offline Sonork: 1668812 Thanks Meter: 39 | imei ripear is iligal bro jus work easy dont ask any one for it |
The Following User Says Thank You to awais ali007 For This Useful Post: |
03-16-2017, 07:33 | #21 (permalink) |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | which cable use for boot Qualcomm cpu i have problem |
The Following User Says Thank You to farukpdm For This Useful Post: |
03-16-2017, 08:08 | #22 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Chittagong, Bangladesh
Member: 1706809 Status: Offline Thanks Meter: 63 | what about county unlock code oppo and security area repair like backup qcn and resotre qcn, repair imei without root in direct flash mode..... it will be so much appreciable for world first and effectiveness. thanks to team |
The Following User Says Thank You to shohidsd1 For This Useful Post: |
03-16-2017, 08:28 | #24 (permalink) |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Micromax Q416 FRP REMOVE Micromax Q416 FRP REMOVE Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01A3E851 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 56AEC4329D093631EE438D925D24AC9C ID_BLOCK_L : 7E15BB12078E30B548A7E82123C2DCFF Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : Micromax ProdName : Q416 ProdModel : Micromax Q416 Device : Q416 AndroidVer: 5.1.1 Manufact. : micromax QLMxCPU : MSM8909 Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Reset Settings [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01A3E851 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 56AEC4329D093631EE438D925D24AC9 C ID_BLOCK_L : 7E15BB12078E30B548A7E82123C2DCFF Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! B.Uttam |
The Following 3 Users Say Thank You to uttam4u2002 For This Useful Post: |
03-16-2017, 08:36 | #25 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
03-16-2017, 08:37 | #26 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | No luck with them for now EDL cable. Just some small amount of asus phones supported. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
03-16-2017, 08:55 | #30 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | VDF600 - ZTE not supported Code: Card found : , v0135 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 05182C93 ID_BLOCK_I : 009600E1 ID_BLOCK_E : 00040000 ID_BLOCK_L : 4B854081B289748C1C826B8FDAACF04C ID_BLOCK_L : 82D93C69BCF55F142E26FAA16FADA700 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to maremestera For This Useful Post: |
