05-21-2017, 17:56 | #33 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Also, by users reports we got much info about problems with native qlm drivers on W8.1/w10 x64 builds. Still thinking about need they or not. | |
05-21-2017, 18:11 | #36 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Android
Member: 1916900 Status: Offline Sonork: .::NIGAM::. Thanks Meter: 81 | yes working now Operation : Identify [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 03153B8B ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 83CC5F7BC1C0086B6A7ECABD119D7D52 ID_BLOCK_L : DF1953F205143EECEB729792ED5985F8 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : BJNB4R Boot Ok! just copy past boot folder & CM2QLM exe in [ v1.11 ] old folder Last edited by .::NIGAM::.; 05-21-2017 at 18:20. |
The Following User Says Thank You to .::NIGAM::. For This Useful Post: |
05-21-2017, 19:01 | #40 (permalink) | |||||
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
hello every one problem in installer don't install with installer
The Following User Says Thank You to Momin_Telecom For This Useful Post: |
05-21-2017, 19:46 | #41 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Bulgaria
Member: 1968946 Status: Offline Thanks Meter: 99 | Team, please fix this error: "Error : Environment is compromised! Re-Install module!"....... Reinstall, reinstall again, but not result. Uninstall previous version, reinstall, but no result. PLESE FIX!!!!!!! |
05-21-2017, 22:54 | #42 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | Card found : , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.12 Error : Environment is compromised! Re-Install module! plz fix problem sir, |
05-22-2017, 05:59 | #45 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Ghana Age: 31
Member: 2207285 Status: Offline Thanks Meter: 127 | first copy the setup to C:\InfinityBox\CM2QLM\ and hit the uninstall file after delet all files and use 7z to extracte the setup thats is it mine is working 1000% |
The Following User Says Thank You to wagonstev For This Useful Post: |
