Old 05-25-2017, 08:25   #16 (permalink)
pshycoboy's Avatar
Member: 1597314
Thanks Meter: 116
Originally Posted by mobi_soft View Post
if possible
add read/write Qcn
after flash no service/emergency problem
If your phone not have signal or inei null after flash just flash with modem with other vertion.
The Following User Says Thank You to pshycoboy For This Useful Post:
Old 05-25-2017, 08:29   #17 (permalink)
Member: 2713606
Thanks Meter: 239
GreaT Team,Have a Good working Time Good Luck Infinity Team
The Following User Says Thank You to Hoshang_Gsm For This Useful Post:
Old 05-25-2017, 08:30   #18 (permalink)
abdul.majid8186's Avatar
Member: 2582370
Sonork: 100.1675531
Thanks Meter: 126
Nice Work
Last Update Show 8940 Boot But This Update Remove
The Following User Says Thank You to abdul.majid8186 For This Useful Post:
Old 05-25-2017, 08:33   #19 (permalink)
Member: 2563413
Sonork: 100.1675794
Thanks Meter: 3
Good Updates,
Non-Stop Updating Team In GSM World.
The Following User Says Thank You to mkashifyounus For This Useful Post:
Old 05-25-2017, 08:40   #20 (permalink)
Member: 1043909
Thanks Meter: 60,926
http://forum.gsmhosting.com/vbb/f296...anual-2179982/
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 05-25-2017, 09:12   #21 (permalink)
Member: 709755
Thanks Meter: 3
All is well but what about imei option sir....
The Following User Says Thank You to PARDEEPRANA For This Useful Post:
Old 05-25-2017, 09:21   #22 (permalink)
Tien Dung GSM's Avatar
Member: 2643704
Sonork: Zalo:0932606079
Thanks Meter: 135
IMEI Repair and QCN file thanks team
The Following 2 Users Say Thank You to Tien Dung GSM For This Useful Post:
Old 05-25-2017, 09:38   #23 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
We work on it as well. Will be universal, easy way for QCN and repair.
The Following 12 Users Say Thank You to JayDi For This Useful Post:
Old 05-25-2017, 09:47   #24 (permalink)
Member: 2499103
Thanks Meter: 60
infinity always the best.thanks for the update .but we need support for Huawei phone.flashing.unlock .bootloader unlock. and many other
The Following User Says Thank You to mimarijaz71 For This Useful Post:
Old 05-25-2017, 09:52   #25 (permalink)
JayDi's Avatar
Member: 462970
Nothing removed, probably it missed in update log.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 05-25-2017, 09:58   #26 (permalink)
scorpions9's Avatar
Member: 1907717
Sonork: 100.1681291
Thanks Meter: 111
Very goood update
The Following User Says Thank You to scorpions9 For This Useful Post:
Old 05-25-2017, 10:09   #27 (permalink)
Member: 1180176
Thanks Meter: 32
One Plus 3 - Erase Factory Reset Protection DONE !!
Operation : Reset Settings [ v1.12 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 820 [MSM8996]
ID_BLOCK_S : AE9FDA09
ID_BLOCK_I : 009470E1
ID_BLOCK_E : 2A703DB9
ID_BLOCK_L : 92912175D8BA4F446E190AD90C7944FD
ID_BLOCK_L : 1039FCC7E2DBA68E0FE36F672779F438
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1
ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000200
UFS Device : SAMSUNG KLUCG4J1CB-B0B1 0800
UFS SectSize : 0x0200
UFS LU0 Size : 0x00000000EC05E000 : 3,69 GiB
--------------UFS Device Info--------------
UFS Total Active LU: 0x6
UFS wManufacturerID: 0x1ce
UFS Boot Partition Enabled: 0x1
UFS LU Write Protect: 0x0
UFS Boot LUN ID: = 0x0
UFS Memory Type: 0x0
UFS LU Total Blocks: 0x0
UFS Supported Memory Types: 0x800f
UFS LUN Enable Bitmask: 0x3f
UFS bConfigDescrLock: 0x0
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:16
The Following 3 Users Say Thank You to Fisiu For This Useful Post:
Old 05-25-2017, 10:26   #28 (permalink)
Member: 1725706
Thanks Meter: 189
Very hot this update for support universall flash storage
br:masoud salamat
The Following User Says Thank You to ISFAHAN_GSM1 For This Useful Post:
Old 05-25-2017, 10:39   #29 (permalink)
Member: 2310475
Thanks Meter: 64
plz add imei repair option
after long time wait ............. imei repair option not add , :confused
after flash imei null , many time we face this problem , plz add network repair , or imei repair option........ plz
The Following User Says Thank You to gulfamkhan For This Useful Post:
Old 05-25-2017, 10:48   #30 (permalink)
martyn911's Avatar
Member: 130762
Sonork: @martyn911
Thanks Meter: 127
Exclamation NOT support - need reset FRP - not support
ZTE 958
AT&T USA sim-lock + FRP active
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 0FBBE830
ID_BLOCK_I : 007050E1
ID_BLOCK_E : 00040000
ID_BLOCK_L : D751B0150BD48B22590AB7709195A862
ID_BLOCK_L : 04E349A282D5FA76A4ED97A641697EEF
Error : Prepare target failed! Unsupported SecureType!
Send log and report.log to support! Include device info also!
Reconnect Power/Cable!
The Following User Says Thank You to martyn911 For This Useful Post:
Page generated in 0.23300 seconds with 9 queries
