05-28-2017, 17:16 | #62 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Kumasi Ghana
Member: 2213704 Status: Offline Thanks Meter: 22 | Please add Vodafone 890N (Qualcomm MSM8926 Snapdragon 400) and ZTE Grand Xmax (Qualcomm MSM8212 Snapdragon 200) support in the next CM2QLM Update. I get SECURED BOOT When connecting. Thanks. ERROR; 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0173F74D ID_BLOCK_I : 007050E1 ID_BLOCK_E : 00480000 ID_BLOCK_L : 7FA5DE24BD2F5F1FD25508640B8B15AC ID_BLOCK_L : 61F01F16A33C197A3A86872117FF9D2C Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to Fg4ty899tt For This Useful Post: |
05-28-2017, 17:34 | #63 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | xiaomi readmi 4 miui 8.2.2 MI accaount reset fail Quote:
The Following User Says Thank You to nahidroman For This Useful Post: |
05-28-2017, 23:30 | #64 (permalink) |
Major Poster Join Date: Apr 2008 Location: west java
Member: 742060 Status: Offline Thanks Meter: 19 | Please add ZTE V9820 (Qualcomm MSM8926 Snapdragon 400) Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.12 Operation : Read Flash [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 01BA933E ID_BLOCK_I : 008050E1 ID_BLOCK_E : 00040000 ID_BLOCK_L : 9636BEDA0587B8AF09CB039260E7C280 ID_BLOCK_L : AD73B2F66D182F0B8F384AC4D0904F60 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to 69_9000 For This Useful Post: |
05-29-2017, 00:07 | #65 (permalink) |
Major Poster Join Date: Jan 2012
Member: 1711037 Status: Offline Thanks Meter: 8 | asus zenfone 3 with snapdragon 820 not supported in frp 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 820 [MSM8996] ID_BLOCK_S : ADA68F89 ID_BLOCK_I : 009470E1 ID_BLOCK_E : 10438996 ID_BLOCK_L : CAD7C1651470EB3722543A49F1CCEFAB ID_BLOCK_L : D14A54114D4F5F85CBFCF713E3B895F5 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! |
The Following User Says Thank You to geronimo2012 For This Useful Post: |
05-29-2017, 05:37 | #66 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Molakalmuru (KARNATAKA) {INDIA
Member: 1891452 Status: Offline Thanks Meter: 29 | A05510 getting this error Card found : CF166680 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.12 Operation : Read Flash [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 00BE19F4 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 767DD8E1C7D6ED55097FC1C271396F5C ID_BLOCK_L : FF93EA7C27D81DE834B62C02328775E5 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to Mohammed Farooq For This Useful Post: |
05-29-2017, 07:46 | #67 (permalink) |
Member: 2213704 Status: Offline Thanks Meter: 22 | ZTE Grand Xmax (Qualcomm MSM8212) ZTE Grand Xmax (Qualcomm MSM8212) Error: Operation : Identify [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 04BC118D ID_BLOCK_I : 008140E1 ID_BLOCK_E : 00040004 ID_BLOCK_L : 216B1D608A9A37AACB8A615A9D1F1A95 ID_BLOCK_L : C7CD2C526113AF171647D1202407F6EB Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Last edited by Fg4ty899tt; 05-29-2017 at 07:56. |
05-29-2017, 17:14 | #68 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: Estonia,UK Bognor Regis Age: 44
Member: 50306 Status: Offline Thanks Meter: 51 | Quote:
Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 821 [MSM8996 Pro] ID_BLOCK_S : BE9A162B ID_BLOCK_I : 0005F0E1 ID_BLOCK_L : 4124368D6B8ADF2B472BBA84B9AC4EBC ID_BLOCK_L : D6AC1B70B100E4541C83AEC63F506693 Use CM2 Internal Loader Loader Sent! Initializing ... i have same problem | |
The Following User Says Thank You to cesarq For This Useful Post: |
05-29-2017, 22:51 | #71 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Belize
Member: 809261 Status: Offline Sonork: 100.61830 Thanks Meter: 100 | please support kyocera phones for password, wipe frp etc no box currently has good support for them. |
The Following User Says Thank You to elnmx For This Useful Post: |
05-30-2017, 00:08 | #72 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Awesome update. It would be great if such autodetect will be added to spd.. need to connect mobile each time change cpu fkr service purpose... |
The Following User Says Thank You to zishhaider For This Useful Post: |
05-30-2017, 07:50 | #73 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Indonesia
Member: 90761 Status: Offline Sonork: 1617079 Thanks Meter: 95 | Quote:
Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 0272F997 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : B7F0534FFDF43C7F166AF6B12591696E ID_BLOCK_L : 3ABAB017A6F191493691323542B46025 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! | |
The Following User Says Thank You to ekel For This Useful Post: |
