Infinity Chinese Miracle-2 QLM v1.14 - SnapDragon 835 / MSM8998 and other stuff Infinity Chinese Miracle-2 QLM v1.14 - SnapDragon 835 / MSM8998 and other stuff Supported CPU List: Qualcomm MSM 8210 (SnapDragon 200) Qualcomm MSM 8212 (SnapDragon 200) Qualcomm MSM 8610 (SnapDragon 200) Qualcomm MSM 8612 (SnapDragon 200) Qualcomm MSM 8226 (SnapDragon 400) Qualcomm MSM 8626 (SnapDragon 400) Qualcomm MSM 8926 (SnapDragon 400) Qualcomm MSM 8228 (SnapDragon 400) Qualcomm MSM 8628 (SnapDragon 400) Qualcomm MSM 8928 (SnapDragon 400) Qualcomm APQ 8009 (SnapDragon 210) Qualcomm MSM 8209 (SnapDragon 210) Qualcomm MSM 8909 (SnapDragon 210) Qualcomm MSM 8916 (SnapDragon 410) Qualcomm MSM 8917 (SnapDragon 425) Qualcomm MSM 8929 (SnapDragon 415) Qualcomm MSM 8936 (SnapDragon 610) Qualcomm MSM 8937 (SnapDragon 430) Qualcomm MSM 8939 (SnapDragon 615) Qualcomm MSM 8940 (SnapDragon 435) Qualcomm MSM 8974/A/AA/AB (SnapDragon 801) Qualcomm MSM 8952 (SnapDragon 617) Qualcomm MSM 8953 (SnapDragon 625) Qualcomm MSM 8956 (SnapDragon 650) Qualcomm MSM 8976 (SnapDragon 652) Qualcomm MSM 8976 Pro (SnapDragon 653) Qualcomm MSM 8992 (SnapDragon 808) Qualcomm MSM 8994 (SnapDragon 810) Qualcomm MSM 8996 (SnapDragon 820) Qualcomm MSM 8996 Pro (SnapDragon 821) Qualcomm MSM 8998 (SnapDragon 835) - MSM8998 supported Identify Factory (RAW) firmware flashing Infinity firmware flashing Firmware reading Memory Tool Reset FileSystem Reset FRP Reset UserLocks ( in case of not encrypted FS ) UserData Recovery ( in case of not encrypted FS ) MemoryTool Automatic eMMC/UFS detection EDL Security operations - Main FH Protocol updated and revised MSM8998 supported MSM8996 Pro for some secure types support revised ( Xiaomi and similar ) Tested and optimized support for big flash storage ( 128+ GiB ) - Flasher Enabled DefaultBoot selection setting ( normally it selected AUTO! Use ONLY if sure about they needs to be changed! ) Optimized FlashFiles selector, some new FW types supported Increased flashing speed - More Secure and Generic types supported MSM8909, MSM8916, MSM8936, MSM8996 : Generic Secure Chinese types, Alcatel and some Oppo MSM8998 : Generic, Xiaomi types support activated - MemoryTool Ultimate tool for custom flashing, modding, forensic and others operations! BootPartition selection revised Sparse Files flashing speed increased up to 3-5 times! Read/write operations now faster 2-4 times Regions detection revised - Service operations improved FormatFS operations revised ( Repair and ForceFix mode ) Xiaomi account reset revised ( stuck on detection parameters fixed ) - Firmware Reader engine updated New types supported ( brand-specific and generic types ) MSM8998 supported Oppo-specific changes and fixes ( nvm errors require reflash with "Force Flash" enabled ) Sparsing big files optimized ( lower memory usage, better size decreasing ) Default regions, device-spicific regions creations activated ( make default factory partitions/files ) -> Unlike other "solutions", CM2 make FIRMWARE, NOT A STUPID PLAIN DUMP ( i.e. cloning ) -> That means all device unique data, security etc. will remain safe after flashing! - Other UFS memory type extended logging support revised ( Xiaomi devices ) Complete core migration for support different FlashTypes and CPU types in automatic model ( MemoryTool and Generic ) Optimized MemoryTool core - if you know how solder FlashIC's - make in-home UFS programmer not a problem :) DataDirect engine updated Some other improvements and fixes Download link #1 - Download link #2 - Download link #3 Upload file to Support - Download files via Torrent Infinity-Box 12 years (2005 - 2017) updates and support as nobody else - News Twitter - Facebook - Telegram |
Karbonn Titanium S1Plus (S1+) Read Firmware From Working Cellphone & Write On Dead. Operation : Identify [ v1.14 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : Read Flash [ v1.14 ] Code: 1. Power Off Phone , Remove battery , Insert back Operation : Flash [ v1.14 ] Code: ForceFlashing : Disabled |
HUAWEI G630-U251 Read Flash.. OK Operation : Read Flash [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 09D156DC ID_BLOCK_I : 008140E1 ID_BLOCK_L : E91B718D28B6A3AE99CE060FC893232B ID_BLOCK_L : 88FB45E4E978E26366513AF3F13C2A11 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : Huawei ProdName : G630-U251 ProdModel : G630-U251 Device : G630-U251 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__G630-U251__G630-U251__G630-U251 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : oemdata.bin [Read Ok] : NON-HLOS.bin [Read Ok] : fs_gc.img [Read Ok] : persist.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cust.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 1172 MiB Done! Elapsed: 00:03:11 |
problem flash redmi 3s |
Please Update MTK Module Last Update 10.08.2016 |
Cm not update please update dongle manager update system |
Update USB drivers to latest version ( from support ) Reboot PC. Use good cable, insert directly in PC motherboard, without front hub or etc. |
detected problem with lonovo models lonovo MTK some modele not detected please solve this cpu problem thanks for QLM UPDATE |
please support cpu qualcom asus , thank support |
where is mtk updateeeeeeeeeeeeeeeeeeeeeeeeee |
why infinity team release updates after ... team provide the same update.. cant u provide worlds first update |
where is mtk update we use mtk tool than qualcomm and the last update about 1 year |
please give me right drivers for qcom phones, i have already installed and flashing phone on QFIL tool and nck dongle but on infinity QLM phone not found, drivers not working. which drivers i should install that work on both? Thanks |
Are you sure? If no need update then why update! Quote:
