09-14-2017, 12:26 | #166 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | format Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 04A498EB ID_BLOCK_I : 008110E1 ID_BLOCK_L : F808629C3BA7ACDF88FD1778C782123A ID_BLOCK_L : 7F16B813048F3FB449A4E9262CC3DDFE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:13 Code: Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 04A498EB ID_BLOCK_I : 008110E1 ID_BLOCK_L : F808629C3BA7ACDF88FD1778C782123A ID_BLOCK_L : 7F16B813048F3FB449A4E9262CC3DDFE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Direct access : Ok! Processing step #1 Processing step #2 Processing step #3 Processing step #4 Processing step #5 Processing step #6 Processing step #7 UserLocks reset passed! 1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart! 2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints 3. In some cases require reboot phone twice or wait up to 5 minutes! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
09-14-2017, 13:47 | #167 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | Huwei g6-u10 flash done still logo MSM8610_HUAWEI_Huawei_ANDR_v4.3_HUAWEI_G6-U10_hwG6-U10_G6-U10 Quote:
09-14-2017, 18:39 | #170 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Molakalmuru (KARNATAKA) {INDIA
Member: 1891452 Status: Offline Thanks Meter: 29 | Qlm v1.15 cant open Bul v1.14 working I already uninstall v1.14 and install fresh v1.15 But still Qlm v1.15 not open Even dont have fault bin And dont have flexihub Team plz tell what to do? |
09-15-2017, 12:15 | #173 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Do you see any error message text or software just do not open silently ? | |
09-15-2017, 21:28 | #175 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2084073 Status: Offline Thanks Meter: 2 | MI5s try to reset mi account fail 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 821 [MSM8996 Pro] ID_BLOCK_S : 82E822FD ID_BLOCK_I : 0005F0E1 ID_BLOCK_L : 731604BF59B8F1F935798C52979E1C8E ID_BLOCK_L : 0472D5A26FD236E6CE757074EDA29441 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : TOSHIBA THGLF2G9J8LBATRH0101 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29,50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x198 UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x801f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! MIAccount reset passed! Complete reset : > If device lock after WiFi - use RESET MI APP > PowerOn device, NOT power WiFi, SIM and etc. Make device setup > Reset MI APP. Device will not have MIServices anymore Done! Elapsed: 00:00:58 what's means Reset MI APP??????? and how can i do???? |
09-16-2017, 09:16 | #177 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Make clean install. Remove QLM folder, but save phdata folder if it contain backups or forensic results. Then install new setup. if still not solve clean ur system means scan for virus | |
