02-07-2018, 18:43 | #287 (permalink) | |
Insane Poster Join Date: Mar 2012 Location: pakistan, islamabad/lahore
Member: 1729557 Status: Offline Sonork: 100.1677910 Thanks Meter: 5 | Quote:
1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : FFAA8844 ERROR : Device stuck in S-EDL! HINT : S-EDL : Reset power. Use BootJIG ( probably it is time to seek TP ) Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : A03D5135 ID_BLOCK_L : 8B776254B0CC0A8716C3849C12D1040E ID_BLOCK_L : 4F7512969A7FB9F43655619835C3D21D Pickup loader from firmware package Loader Sent! Initializing ... ERROR : FH Configuration failed! HINT : Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : A03D5135 ID_BLOCK_L : 8B776254B0CC0A8716C3849C12D1040E ID_BLOCK_L : 4F7512969A7FB9F43655619835C3D21D Pickup loader from firmware package Loader Sent! Initializing ... ERROR : FH Configuration failed! HINT : Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! plz help | |
02-07-2018, 18:44 | #288 (permalink) |
Member: 1729557 Status: Offline Sonork: 100.1677910 Thanks Meter: 5 | Any solution plz Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : FFAA8844 ERROR : Device stuck in S-EDL! HINT : S-EDL : Reset power. Use BootJIG ( probably it is time to seek TP ) Reconnect Power/Cable! |
The Following User Says Thank You to soharwardian For This Useful Post: |
