07-31-2017, 06:44 | #106 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Ahmedabad, India Age: 34
Member: 2286149 Status: Offline Thanks Meter: 34 | Device:YU5010 Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0E0BEC2E ID_BLOCK_I : 007050E1 ID_BLOCK_L : 39429BD1461069FDA33DDEECF356A8CE ID_BLOCK_L : 30546702F969BC8CC5D8B8228E7F1D7E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! MSC format Ok! USERDATA format Ok! CACHE format Ok! Done! Elapsed: 00:01:36 Reconnect Power/Cable! |
07-31-2017, 20:11 | #110 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Ayphone Technic
Member: 368730 Status: Offline Thanks Meter: 180 | Why in v1.15 it always error detection... Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0CA9A5C2 ID_BLOCK_I : 008140E1 ID_BLOCK_L : E28935644FE4770DB8504D21757E37B2 ID_BLOCK_L : 8F5DA73E8E4D2A83410F44D90396659D Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0CA9A5C2 ID_BLOCK_I : 008140E1 ID_BLOCK_L : E28935644FE4770DB8504D21757E37B2 ID_BLOCK_L : 8F5DA73E8E4D2A83410F44D90396659D Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
08-01-2017, 04:18 | #111 (permalink) |
Member: 368730 Status: Offline Thanks Meter: 180 | Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 01E190D4 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 4A3794B23A09FFA2D3A53372E654A4AB ID_BLOCK_L : AB552F86496062B8A706C3C6B125F1B4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : AJNB4R Boot Ok! Brand : Xiaomi ProdName : kenzo ProdModel : Redmi Note 3 Device : kenzo AndroidVer: 6.0.1 Manufact. : Xiaomi SysPatch : MMB29M DevComTime: 3/30/2017 4:33:54 AM QLMxCPU : MSM8952 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 01E190D4 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 4A3794B23A09FFA2D3A53372E654A4AB ID_BLOCK_L : AB552F86496062B8A706C3C6B125F1B4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : AJNB4R Boot Ok! Brand : Xiaomi ProdName : kenzo ProdModel : Redmi Note 3 Device : kenzo AndroidVer: 6.0.1 Manufact. : Xiaomi QLMxCPU : MSM8952 DevInfo : MSM8952__Xiaomi__Xiaomi__ANDR_v6.0.1__Redmi_Note_3 __kenzo__kenzo Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! |
08-01-2017, 06:52 | #112 (permalink) | |||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Does device connect 9006 mode? Quote:
08-01-2017, 18:18 | #113 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 43
Member: 136054 Status: Offline Thanks Meter: 5 | Operation : Read PatternLock [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : C24C3A55 ID_BLOCK_I : 009900E1 ID_BLOCK_L : A54AEB36F402052EE7BF0A407A321AD0 ID_BLOCK_L : 7B35D3752E697FA4C6E6D9A8F476D5D5 Use CM2 Internal Loader FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! plz Add this model oppo cph1613 |
08-01-2017, 18:51 | #114 (permalink) | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
08-01-2017, 20:47 | #115 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | zte axon 7 not supported zte axon 7 mini b2017g not supported Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 019CAE2F ID_BLOCK_I : 009720E1 ID_BLOCK_E : 00000004 ID_BLOCK_L : C066EFD1F33B2A63F5838B3B19BB3E4C ID_BLOCK_L : 27C108D46D7CB55C5D48B9D59A895DB0 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
08-02-2017, 14:45 | #116 (permalink) | |
Crazy Poster Join Date: Dec 2013 Location: Harare, Zimbabwe
Member: 2076822 Status: Offline Thanks Meter: 2 | Quote:
https://www.4shared.com/s/fKlOJMzjkca | |
08-10-2017, 08:35 | #119 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | oppo CPH1613 Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 63B9C1F6 ID_BLOCK_I : 009900E1 ID_BLOCK_L : 04AD4C9713A3E6CF4610EBA39993BB31 ID_BLOCK_L : ECA8BEE2B3FED21359934A1D5919A24A Use CM2 Internal Loader FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! |
