08-10-2017, 15:04 | #121 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Ahmedabad, India Age: 34
Member: 2286149 Status: Offline Thanks Meter: 34 | Code: Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 134C44B9 ID_BLOCK_I : 007050E1 ID_BLOCK_L : CE36ACAA05919E89762B252AF54CC404 ID_BLOCK_L : 077EC06B6CF767ECE1CC817E74BBB596 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Minor Error! Skip! Minor Error! Skip! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
08-11-2017, 09:30 | #125 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Need a complete fresh install. Copy all important backup from C:\InfinityBox\CM2QLM to a safe place, uninstall CM2QLM, delete CM2QLM folder from C:\InfinityBox\ Install latest version of CM2QLM and run software. Br. Infinity Box Team. | |
08-14-2017, 15:49 | #130 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Wht Error coming if automatic closing then do this Make clean install. Remove QLM folder, but save phdata folder if it contain backups or forensic results. Then install new setup. if still not solve clean ur system means scan for virus |
08-16-2017, 08:03 | #132 (permalink) |
Member: 2286149 Status: Offline Thanks Meter: 34 | Hello sir, i recieved another same set today, redmi note prime dual sim, after reset mi account in cm2, still asking mi account here is persist bin file link https://drive.google.com/open?id=0B7...nY1cDU1NXVkREE Last edited by Jamil69; 08-16-2017 at 08:09. |
08-17-2017, 06:39 | #135 (permalink) | ||
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Code: hello after i install v1.15 qlm not work i install 1.14 work what could be the problem Do u all have fault.bin in ur qlm folder if yes then attach it here team will say wht to do,, no fault.bin then do this,,Make clean install. Remove QLM folder, but save phdata folder if it contain backups or forensic results. Then install new setup. if still not solve clean ur system means scan for virus | ||
The Following User Says Thank You to princesaddam For This Useful Post: |
