12-16-2017, 08:48 | #46 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Kumasi Ghana
Member: 2213704 Status: Offline Thanks Meter: 22 | Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0173F74D ID_BLOCK_E : 00480000 ID_BLOCK_L : 7FA5DE24BD2F5F1FD25508640B8B15AC ID_BLOCK_L : 61F01F16A33C197A3A86872117FF9D2C Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
12-16-2017, 10:46 | #47 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 687743 Status: Offline Thanks Meter: 18 | Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 008A5707 ID_BLOCK_L : EA744F8ACC997F65B83CD9F6AF694013 ID_BLOCK_L : 1AF47B0DCF2E1013AA81761A0192AC84 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! its htc desire 816 not supported???? i used the latest version how to send log or report log so that my phone wil be supported in next update??? |
12-16-2017, 11:45 | #49 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
12-16-2017, 11:46 | #50 (permalink) | |
12-16-2017, 13:16 | #52 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | repaire imei failed Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 04218875 ID_BLOCK_L : 72F2E816C12D5A553267E9F6310888C0 ID_BLOCK_L : F88B35949908B233D6216AA3A14C5A61 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Wipe Security Partitions Erase : FSG Erase : MODEMST1 Erase : MODEMST2 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00009601 MODHW : 0000100C BUILD : MPSS.JO.1.0.c5.8-00005-M8909EAAAANVZM-2.38452.1.39031.1 RTIME : Apr 7 201619:32:40 BTIME : Dec 30 201501:00:00 DEVST : 8909.lwg Update IMEI[1] : 869428020195163 Record update FAILED! READ-ONLY! Security Wipe required! Update IMEI[2] : 869428020195171 Record update FAILED! READ-ONLY! Security Wipe required! Write done! Reboot device, if it not restart! Hint : QCN write and Factory Reset is required to finish process completely! Done! Elapsed: 00:00:02 Reconnect Power/Cable! |
12-16-2017, 13:48 | #53 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | Infinity Chinese Miracle-2 QLM after mi account remove show Device may relock back on WiFi/Network enable! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 610 [MSM8936] ID_BLOCK_S : 0107C429 ID_BLOCK_L : 2562E1DD6F66AA0D84D868DFB323DBFC ID_BLOCK_L : D12F45FC331A0CE29D6CA5A0DF4F9BCE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! MIAccount reset passed! Device may relock back on WiFi/Network enable! |
12-16-2017, 13:54 | #55 (permalink) |
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | Infinity Chinese Miracle-2 QLM after mi account remove show Device may relock back on WiFi/Network enable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 610 [MSM8936] ID_BLOCK_S : 0107C429 ID_BLOCK_L : 2562E1DD6F66AA0D84D868DFB323DBFC ID_BLOCK_L : D12F45FC331A0CE29D6CA5A0DF4F9BCE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Xiaomi ProdName : ferrari ProdModel : Mi 4i Device : ferrari AndroidVer: 5.0.2 Manufact. : Xiaomi QLMxCPU : MSM8916 DevInfo : MSM8916__Xiaomi__Xiaomi__ANDR_v5.0.2__Mi_4i__ferra ri__ferrari Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : sec.dat [Read Ok] : misc.img [Read Ok] : fs_gc.img [Read Ok] : NON-HLOS.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8936 / eMMC Firmware Size : 1946 MiB Done! Elapsed: 00:03:26 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 610 [MSM8936] ID_BLOCK_S : 0107C429 ID_BLOCK_L : 2562E1DD6F66AA0D84D868DFB323DBFC ID_BLOCK_L : D12F45FC331A0CE29D6CA5A0DF4F9BCE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! MIAccount reset passed! Device may relock back on WiFi/Network enable! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
12-16-2017, 14:01 | #57 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Alipur
Member: 2683134 Status: Offline Thanks Meter: 59 | Please update cm2mtk We Can't See The Greatest Chinese Tool Saying that Not Supported Yet |
The Following User Says Thank You to Love_InsPeXtor For This Useful Post: |
12-16-2017, 14:22 | #59 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,103 | Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 04218875 ID_BLOCK_L : 72F2E816C12D5A553267E9F6310888C0 ID_BLOCK_L : F88B35949908B233D6216AA3A14C5A61 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : STREAM ProdName : E50AE ProdModel : B3 Simply Device : E50AE AndroidVer: 5.1.1 Manufact. : SARL BOMARE COMPANY SysPatch : LMY47V DevComTime: 25/04/2016 11:51:19 QLMxCPU : MSM8909 QLMxPRJ : L1211.6.02.03.DZ00 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:08 Reconnect Power/Cable! its hisens technology device after backup qcn only one imei writed but phone have 2 sim can you add multi sim qcn backup |
