02-06-2018, 09:04 | #167 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Philippines
Member: 436121 Status: Offline Thanks Meter: 40 | Sir JayDi is my posted earlier about ZTE Blade Q Lux is enough or you still need this logs below to support exclusive phone? Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 12C8FBFC ID_BLOCK_E : 00040000 ID_BLOCK_L : AF90A1C09F0B963EAA31D4CD67A1B884 ID_BLOCK_L : EC84BCD10528D5AA3825460D55264EBD Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
02-06-2018, 18:32 | #169 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Yangon Age: 29
Member: 2006794 Status: Offline Sonork: 100.1664636 Thanks Meter: 164 | SAMSUNG SCV33 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : EF1FDD2A ID_BLOCK_E : 00200000 ID_BLOCK_L : 04CC834A48B7FE53856C008BA1CC4339 ID_BLOCK_L : DD89B17FEFC8DFF66E10EC04D2B7C6E7 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : EF1FDD2A ID_BLOCK_E : 00200000 ID_BLOCK_L : 04CC834A48B7FE53856C008BA1CC4339 ID_BLOCK_L : DD89B17FEFC8DFF66E10EC04D2B7C6E7 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : EF1FDD2A ID_BLOCK_E : 00200000 ID_BLOCK_L : 04CC834A48B7FE53856C008BA1CC4339 ID_BLOCK_L : DD89B17FEFC8DFF66E10EC04D2B7C6E7 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Enable DIAG ( over ADB ) [ v1.16 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : EF1FDD2A ID_BLOCK_E : 00200000 ID_BLOCK_L : 04CC834A48B7FE53856C008BA1CC4339 ID_BLOCK_L : DD89B17FEFC8DFF66E10EC04D2B7C6E7 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : EF1FDD2A ID_BLOCK_E : 00200000 ID_BLOCK_L : 04CC834A48B7FE53856C008BA1CC4339 ID_BLOCK_L : DD89B17FEFC8DFF66E10EC04D2B7C6E7 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Memory Tool Init [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : EF1FDD2A ID_BLOCK_E : 00200000 ID_BLOCK_L : 04CC834A48B7FE53856C008BA1CC4339 ID_BLOCK_L : DD89B17FEFC8DFF66E10EC04D2B7C6E7 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! PLZ HELP SAMSUNG 9008 Flash |
02-06-2018, 19:58 | #170 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | Asus ZB500KL MSM8916 not supported Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0E82AEED ID_BLOCK_I : 007050E1 ID_BLOCK_E : 00010001 ID_BLOCK_L : 3D3A38FDB891F466D86F9F1DE13F964C ID_BLOCK_L : BEB8D772170CD592C9567DEB8281A39C Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
02-07-2018, 02:24 | #171 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Central Igorot
Member: 2041408 Status: Offline Thanks Meter: 38 | |
02-07-2018, 10:02 | #172 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,103 | this wing tech loader its impossible to get for asus ZB500KL its possible to modify any loader to boot this device 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0E82AEED ID_BLOCK_I : 007050E1 ID_BLOCK_E : 00010001 ID_BLOCK_L : 3D3A38FDB891F466D86F9F1DE13F964C ID_BLOCK_L : BEB8D772170CD592C9567DEB8281A39C Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
02-11-2018, 17:00 | #174 (permalink) |
Member: 436121 Status: Offline Thanks Meter: 40 | . Please support fully thi mode Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 013D3157 ID_BLOCK_E : 00010001 ID_BLOCK_L : 0D9D2316C4FB0C4B271AC7754D23B555 ID_BLOCK_L : CC7E642AE17E761BDE13B648D2DC3FFE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Brand : asus ProdName : WW_Phone ProdModel : ASUS_X00DD Device : ASUS_X00DD AndroidVer: 7.1.1 Manufact. : asus QLMxCPU : MSM8937 DevInfo : MSM8937__asus__asus__ANDR_v7.1.1__ASUS_X00DD__ASUS _X00DD__WW_Phone ReportFile : C:\InfinityBox\CM2QLM\QLM_16report.log Send report to mail : [email protected] with title "QFW" ! INFO : Device is not supported yet! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
02-12-2018, 07:44 | #175 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2810432 Status: Offline Thanks Meter: 0 | Hi guys, I'm really newbie here so please be gentle. I have Snaprdragon 835 based smartphone (Essential PH-1) and IMEI was erased. I could not find suitable section so I'm asking here because this Infinity-box seems right for my situation. Would somebody please tell me instruction about what I need to purchase and what to do next? |
02-13-2018, 04:09 | #177 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
02-13-2018, 04:19 | #178 (permalink) | |
Member: 2810432 Status: Offline Thanks Meter: 0 | Quote:
Very thanks for your reply. Do you mean that I could recover IMEI by using CM2 qlm, without any hardware device such as Infinity-Box dongle? If you meant it, I can definitely download CM2 qlm(it is a software right?) and try to recover IMEI. | |
02-13-2018, 04:49 | #179 (permalink) | |
Kindly give the phone to technician to repair for you otherwise u will damage your phone. | |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
02-13-2018, 05:01 | #180 (permalink) | |
Yeah, I am a really newbie, would you give me a rough instructions? (not software skill parts) I think I need to buy Infinity-Box from a reseller and download CM2 qlm to get my phone recognized. | |
