01-07-2019, 15:51 | #376 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Czech Republic
Member: 1993 Status: Offline Thanks Meter: 94 | |
The Following User Says Thank You to Eerchant For This Useful Post: |
01-26-2019, 17:12 | #383 (permalink) |
Junior Member Join Date: Nov 2008 Location: iran-mobile ehsan Age: 35
Member: 902520 Status: Offline Thanks Meter: 7 | huawei y625 Operation : Enable DIAG ( over ADB ) [ v1.16 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
01-26-2019, 17:14 | #384 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
01-26-2019, 21:21 | #386 (permalink) |
Member: 902520 Status: Offline Thanks Meter: 7 | problem solved huawei y625-u32 imei repier unistall adb driver and update port phone conected best software for qoalcomm cpu tanx infinity team Card found : C768**** , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Enable DIAG ( over ADB ) [ v1.16 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Enabling DIAG mode ... New PORT should appear. Install DIAG drivers, if need Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00008141 MODHW : 00000FF9 BUILD : 8x10_PL190335_20141120 RTIME : Jan 30 201510:09:11 BTIME : Jan 29 201502:00:00 DEVST : BAAAANWZ Update IMEI[1] : 8679*****586321 Record update Ok! Update IMEI[2] : 8679*****626192 Record update Ok! Write done! Reboot device, if it not restart! Hint : QCN write and Factory Reset is required to finish process completely! Done! Elapsed: 00:00:03 Reconnect Power/Cable! |
The Following User Says Thank You to ehsan67 For This Useful Post: |
02-01-2019, 14:47 | #389 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | infinity team please add this chip Card found : 3xxxxxxx, v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : 240B1EE8 ID_BLOCK_E : 00510000 ID_BLOCK_L : 3DC0E7FF45D60ACBEA35736F5BD49500 ID_BLOCK_L : 63783392DC352E0836AFBE5F0E271963 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
02-01-2019, 17:08 | #390 (permalink) | |
