12-21-2017, 13:17 | #92 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | zte blade S6 Quote:
The Following 2 Users Say Thank You to Steve-1 For This Useful Post: |
12-21-2017, 15:04 | #93 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Ranchi
Member: 1841619 Status: Offline Thanks Meter: 50 | Zuk 2 Z2132 MSM8996 Connect Failed Frp Failed, Flash failed, Factory Reset Error Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 820 [MSM8996] ID_BLOCK_S : 54D0E936 ID_BLOCK_L : B534592D58577FED8BBD3B74FFC73D14 ID_BLOCK_L : A014BD058FBAE5AF1143ECFBF3C3B0DA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM , FLASH : , mVER : ExtInfo : 0x00000000/00000000/00000000/00000000/00000000 Boot Ok! CM2QCM Hang |
12-21-2017, 15:24 | #94 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 0078BAE2 ID_BLOCK_E : 00040000 ID_BLOCK_L : 3DBD2386629EE3F0B7A698362B8B4BD6 ID_BLOCK_L : E85B87C447A24A6BBEA2400D6BE576A8 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
12-21-2017, 22:08 | #95 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Quote:
12-23-2017, 19:13 | #96 (permalink) |
Junior Member Join Date: Jun 2014 Location: jordan
Member: 2213126 Status: Offline Thanks Meter: 22 | Please add Huawei Y7 Prime TRT-AL00A Qualcomm MSM8940 Snapdragon 435 https://m.gsmarena.com/huawei_y7_prime-8632.php |
The Following 2 Users Say Thank You to ahmad omairat For This Useful Post: |
12-25-2017, 06:25 | #102 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan Age: 24
Member: 2488001 Status: Offline Sonork: 100.1669288 Thanks Meter: 295 | hello how solved this problem Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0601CA48 ID_BLOCK_E : 00390057 ID_BLOCK_L : EA7215E36F75AFD356462FEDF24143DB ID_BLOCK_L : 2B8151A92F60975AA2F2DB2CEFF82F47 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0601CA48 ID_BLOCK_E : 00390057 ID_BLOCK_L : EA7215E36F75AFD356462FEDF24143DB ID_BLOCK_L : 2B8151A92F60975AA2F2DB2CEFF82F47 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Read QCN (NVM) [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
12-25-2017, 08:14 | #103 (permalink) | |
