12-25-2017, 12:37 | #106 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | How to renew support (and use latest software updates): If you have Infinity-Credits at your IOS Account: - Login to your IOS Account - http://www.infinity-box.com/service/ - go to `Products` menu - Select `Infinity-Box/Dongle 1 year Updates/Support Renew` - Enter your S/N If you do not have Infinity Credits at your IOS Account: - Contact to any Seller - http://www.infinity-box.com/buy/ |
12-26-2017, 11:50 | #110 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | format not done Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 07E38EEF ID_BLOCK_L : F40C66903FABD0D38CE1137CBB860E3E ID_BLOCK_L : BED57BD2C74EF075886728E1E3021C3F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 07E38EEF ID_BLOCK_L : F40C66903FABD0D38CE1137CBB860E3E ID_BLOCK_L : BED57BD2C74EF075886728E1E3021C3F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 729854631 Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
12-26-2017, 13:57 | #112 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Card found : 935BDA93 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 415 [MSM8929] ID_BLOCK_S : 009A1CC1 ID_BLOCK_E : 00040000 ID_BLOCK_L : E0D5E48FDA44D3716D0C8F8022E687C3 ID_BLOCK_L : 1E7A5223FBDA27780AF3B8DFA7F49C4F Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 415 [MSM8929] ID_BLOCK_S : 009A1CC1 ID_BLOCK_E : 00040000 ID_BLOCK_L : E0D5E48FDA44D3716D0C8F8022E687C3 ID_BLOCK_L : 1E7A5223FBDA27780AF3B8DFA7F49C4F Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
12-27-2017, 03:53 | #114 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | ASUS_X00BD FRP Done Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0B284E7F ID_BLOCK_E : 00010001 ID_BLOCK_L : 97AF6638FE7796ECC0D42F1BA8F5142D ID_BLOCK_L : DC89B1156DAE1D0A5CBE3D50096FF3A4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : asus ProdName : WW_Phone ProdModel : ASUS_X00BD Device : ASUS_X00BD AndroidVer: 5.1.1 Manufact. : asus SysPatch : LMY47V DevComTime: 2/22/2017 8:52:55 AM QLMxCPU : MSM8610 USERData : NORMAL GCSec : NORMAL Done! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0B284E7F ID_BLOCK_E : 00010001 ID_BLOCK_L : 97AF6638FE7796ECC0D42F1BA8F5142D ID_BLOCK_L : DC89B1156DAE1D0A5CBE3D50096FF3A4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Remove FRP Reset Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:28 |
The Following 2 Users Say Thank You to buffer2k11 For This Useful Post: |
12-27-2017, 20:37 | #115 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Czech republic Age: 54
Member: 56634 Status: Offline Thanks Meter: 71 | VFD 511 not vork Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0ACE98E4 ID_BLOCK_E : 00040000 ID_BLOCK_L : C7E8C9A8E763FE569229ACA50FC9A0FC ID_BLOCK_L : EA8EA6D70F2EEBAC363F4C0B6B3848B3 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! can i help mi |
12-28-2017, 07:44 | #116 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO V7 PLUS 1716 AndroidVer: 7.1.2 PATTERN & FRP REMOVE Done SUCCESSFULLY REMOVE PATTERN & FRP LOCK(VIVO V7 PLUS 1716)USB SUCCESS REPORT THANKS INFINITY-BOX TEAM |
12-28-2017, 08:12 | #119 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 450219 Status: Offline Thanks Meter: 119 | kyocera c6742a Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 05B656FD ID_BLOCK_E : 00390027 ID_BLOCK_L : 3DAFD834B2A2622409F3F4183F8EF404 ID_BLOCK_L : 9ECAEA1C64D5C80F6F498E7BB0459A0A Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
The Following User Says Thank You to mr.Dubai For This Useful Post: |
