01-01-2017, 12:29 | #1 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | Infinity Chinese Miracle-2 /Qualcomm Mobile Driver FiX (windows 7/8.1/10) Universal Tut For Fix Driver problom in all windows Connect Phone in EDL Mode ............................................... 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! .................................................. . Now If You Have (Qualcomm+HS-USB+QDLoader+9008) Remove Driver Dont Reboot Need To Disable Driver Signature Enforcement Disabling method for Windows 7 64-bit: Permanent method:
Temporary method:
Disabling method for Windows 8.1 & 10 64-bit: Permanent method:
2.bcdedit.exe -set TESTSIGNING ON
Temporary method:
After All Of This Instal This Driver Download Link Click On This (DPInst.exe) Its Will Be instal Driver Connect Phone And Enjoy Press Thanks If Help You |
The Following 5 Users Say Thank You to masoudsoftwrae For This Useful Post: |
05-20-2020, 13:46 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I strongly suggest you download files only from trusted sources ! Infinity support area - https://www.infinity-box.com/support/ |
