06-17-2015, 08:57 | #16 (permalink) | |
Let me ask two questions: 1. What is this thread name ? 2. What is your IQ level ? To be honest I have a real job in other field but not in gsm. I am a doctor and its very interesting for me to read this forum and collect information for my dissertation. So if you can give me an answer to my questions this helps me a lot. With love and best wishes to you and your family ! Your Support Team ! | |
06-17-2015, 09:01 | #17 (permalink) | |
I am really tred to repeat from year to year that ugly antivirus software very often can not understand that its protected software but not a virus. You have the next options: 1. Disable Antivirus and continue 2. Use more smart Antivirus | |
06-17-2015, 09:54 | #18 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | RDA8851 Repair IMEI success Code: Operation : Factory Area Rebuild [Repair IMEI] Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4005 CPU_CN : RDA Mirco CT , RDA8851 ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 8809 , 00400000 Use : 8809_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Read Factory Sector ... Read Ok , verify Detected 1 Sim Slot(s) Current Phone IMEI : IMEI1 : FFFFFFFFFFFFFFF New Phone IMEI : IMEI1 : 35214569874563-2 IMEI2 : 35214569874563-2 Build Factory Sector Write Factory Sector CSD WR : 81C058F4 , 81C05908 CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Verify Factory Sector Sector Verifyed! IMEI Write Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to kabul For This Useful Post: |
06-17-2015, 14:34 | #21 (permalink) | |
06-17-2015, 16:49 | #24 (permalink) | |
06-23-2015, 18:04 | #27 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Hi-Tech S300i Hi-Tech S300i Pattern Lock Code: Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Ok Reboot Phone Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
06-29-2015, 13:11 | #28 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn A108Plus (A108+) Flashing Done By Infinity CM2RDA Operation : Flash Code: ======= Settings Settings : Factory Settings Enabled ======= Flash Files set for flashing : RDATotal File : UTLA108Plusv1009_05-02-2015_rda_total.bin Load Ok : PDL1 Load Ok : PDL2 Load Ok : bootloader Load Ok : boot Load Ok : system Load Ok : modem Load Ok : customer Load Ok : recovery Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! [PDL] : Setting FlashMode ... [PDLBoot] : Sending First PDL ... [PDLBoot] : First Boot Ok! [PDLBoot] : Sending Second PDL ... [PDLBoot] : Second Boot Ok! Boot Finished! Handshake with FL Ok! Factory Defaults Enabled, will reset UserData and Settings! Format UDA partition ... Format USER Ok [PDLFlash] : Sending All Images [PDLFlash] : Processing now BOOTLOADER File : UTLA108Plusv1009_05-02-2015_rda_total.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now BOOT File : UTLA108Plusv1009_05-02-2015_rda_total.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now SYSTEM File : UTLA108Plusv1009_05-02-2015_rda_total.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now MODEM File : UTLA108Plusv1009_05-02-2015_rda_total.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now CUSTOMER File : UTLA108Plusv1009_05-02-2015_rda_total.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now RECOVERY File : UTLA108Plusv1009_05-02-2015_rda_total.bin Flashing ... [PDLFlash] : Flash region done! Flashing Done! Reboot Phone Elapsed: 00:02:12 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
07-07-2015, 12:17 | #29 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Intex Aqua R3 make Calbration file and Format done- Code: Chinese Miracle II [RDA module] v 1.02 Operation : Read FullFlash ======= Settings Settings : Make Calibration file Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Calibration read done Verify and build IFC Calibration Data Saved to : RDA8810_Calibration.ifc Reboot Phone Elapsed: 00:01:04 Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Ok Reboot Phone Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
