06-29-2015, 04:21 | #16 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | i am waiting for spd 8810 6820 spport from a long time |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
06-29-2015, 04:45 | #17 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | Quote:
yes I'm working Best with activation SPT and miracle-2 test version activated please see here screen shot how to activated miracle-2 test version free pease read here Thank you Infinity Team | |
06-29-2015, 06:24 | #23 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Ktouch-a173g Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : Error BUT FORMAT OK.... LOG HERE- Card found: S/N 8F78:0128 Chinese Miracle II [SPD module] v 1.02 Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : Error ---- PATTERN LOCK FAIL Done! Elapsed: 00:07:51 Reconnect Power/Cable! Operation : Format File System [ v1.02 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
06-29-2015, 08:05 | #27 (permalink) | |||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
06-29-2015, 08:10 | #28 (permalink) | ||||
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | as you seen team working hard step by step - PPl always need much - we are trying to add 1st new - as you said 6820, if we will give you 6810 you will cry for mtk just wait and keep patience we are always try to best yes we are working hard keep patience Quote:
Due to some technical reasons we CAN NOT activate Infinity-Box Dongle and Chinese Miracle 2 for Infinity-Box [BEST] and/or Infinity CDMA-Tool users. We are working in this direction but we can not tell you any time when this work will be finished.- you can also buy infinity dongle Quote:
Really? Its not good why are you using that? do you know we are world 1st who give read pattern 77xx cpu - you are just crying for 6820 but its not a big thing - but we will think about you yes find Factory firmware and flash it by Grate CM2 Quote:
May Be But Let Him 1st Flash By Og Pac File | ||||
