06-29-2015, 09:48 | #31 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: pakistan jhelum
Member: 1261180 Status: Offline Sonork: 100.1590645 Thanks Meter: 97 | Quote:
06-29-2015, 09:56 | #32 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Rest things will be. It solve supported CPU's. | |
06-29-2015, 11:36 | #33 (permalink) |
Insane Poster Join Date: May 2015
Member: 2393670 Status: Offline Thanks Meter: 14 | how about SPD SC7701B PLEASE !!! it is not spd android !!! hello to infinity box service !!! need this new cpu to next update please !!! SPD SC7701B !!! NB! this cpu is not spd android . |
The Following User Says Thank You to kasykasy For This Useful Post: |
06-29-2015, 13:37 | #35 (permalink) |
Freak Poster Join Date: Jan 2009 Location: INDIA,U.P.BALLIA
Member: 947347 Status: Offline Sonork: 100.108278 Thanks Meter: 21 | Intex Aqua V+ Operation : Read PatternLock [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 42351 Done! Elapsed: 00:04:46 Reconnect Power/Cable! |
The Following User Says Thank You to poojadooj For This Useful Post: |
06-29-2015, 14:04 | #37 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn A9s Read Pattern Lock Done Like Dream Become True. Operation : Check/Read Info [ v1.02 ] Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 175 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : w138_cjy_251 Model Brand : Karbonn Model Device: w138_cjy_251 AndrVersion : 4.4.2 BaseBand CPU: W138_CJY_251 CompileDate : 1410325386 Project Ver : KOT49H test-keys Model Ext : Karbonn A9s Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Read PatternLock [ v1.02 ] Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 175 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader eMMC v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 147863259 Done! Elapsed: 00:00:25 Reconnect Power/Cable! I Was Freeze Before Reading This : PatternLock Sequence : 147863259 |
The Following 4 Users Say Thank You to MyGSM World For This Useful Post: |
06-29-2015, 18:48 | #38 (permalink) | |
Does it hard read previous posts? | |
07-01-2015, 14:30 | #45 (permalink) |
Member: 947347 Status: Offline Sonork: 100.108278 Thanks Meter: 21 | Chinese Miracle II [SPD module] v 1.02 Samsung E1200Y flashing problem Chinese Miracle II [SPD module] v 1.02 FastCheck : SPD65xx Load file... Platform : MOCOR_W13.09_FP_R5.0.2_Debug sc6500_samsung_EiderVESS_E1200Y_SWA ExtInfo : LevelofLock 00000000 00000000 Project : SC6500_SAMSUNG HWInfo : SC6500_EiderVESS Compile : 09-24-2014 10:56:19 Load Ok Operation : Flash [ v1.02 ] ======= Flash Files set for flashing : Reconnect Power/Cable! Chinese Miracle II [SPD module] v 1.01 Samsung E1200Y flashing ok |
