11-17-2016, 02:47 | #17 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | @All users, Having trouble with 77xx series booting failure, Try this and post result.. You will definitely get success... P.s: select correct boot first.. |
The Following User Says Thank You to chandanps18 For This Useful Post: |
11-17-2016, 04:25 | #22 (permalink) |
Freak Poster Join Date: Dec 2014 Location: KPK Age: 34
Member: 2304199 Status: Offline Sonork: 100.1656573 Thanks Meter: 203 | HOTWAV venus x11 Write Failed all CPU check but not work Chinese Miracle II [SPD module] v 1.24 Loading : T13_HOTWAV_USER_2SIM_64+4_B1_A5_201605242024.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : T13_HOTWAV_USER_2SIM_64+4_B1_A5_201605242024 FastCheck : 0x0051DBACC7 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem T13 b1+b5 with RDA RAMP&CAL&AUDIO.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_pike_modem.bin File : DSP_DM_G2.bin File : SC8800G_pike_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : oem.img File : persist.img File : sysinfo.img File : userdata.img File : hotwav.bmp File : htc.bmp File : huawei.bmp File : cache.img File : u-boot.bin File : SC77xx.xml Load Ok! Operation : Flash [ v1.24 ] ======= Flash Files set for flashing : [ MCU ] : T13_HOTWAV_USER_2SIM_64+4_B1_A5_201605242024.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : T13_HOTWAV_USER_2SIM_64+4_B1_A5_201605242024 File : fdl1.bin File : fdl2.bin File : nvitem T13 b1+b5 with RDA RAMP&CAL&AUDIO.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_pike_modem.bin File : DSP_DM_G2.bin File : SC8800G_pike_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : oem.img File : persist.img File : sysinfo.img File : userdata.img File : hotwav.bmp File : htc.bmp File : huawei.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! |
11-17-2016, 05:27 | #29 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: pakistan Age: 39
Member: 1789762 Status: Offline Sonork: 1612770 Thanks Meter: 51 | qmobile m95 7731 chp not working flashing Quote:
PMTManager : Load 0x17 records PMTManager : PMT Update Failed!!! Selected firmware doesn't match to current HW or EMPTY battery! Flashing terminated! Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong If phone work normally - check correct selection (Model,FlashType)! | |
