03-12-2017, 17:27 | #227 (permalink) |
Freak Poster Join Date: Jul 2011
Member: 1609352 Status: Offline Thanks Meter: 17 | SuperTAB S7G format and reset done Operation : Format File System / Reset Settings [ v1.22 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001556F7000 State : 0x0001 Mount : /cache Size : 0x0000000029E00000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
03-16-2017, 08:01 | #230 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Ahmedabad, India Age: 34
Member: 2286149 Status: Offline Thanks Meter: 34 | samsung b313e user lock read done, but there is no code showing in cm2spd. phone asking code in CONTACTS. Here is log.. Operation : Read User Code [ v1.24 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 39 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0019 0000 [0] Flash VEN : GigaDevice , GD25LQ256 [0] Flash CAP : 02000000 Check data... Can take some time User Code : I Done! Elapsed: 00:02:20 |
03-16-2017, 09:01 | #231 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Micromax Q341 SC7731G Code: Card found: S/N : *** , v0135 Chinese Miracle II [SPD module] v 1.24 Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Q341 Model Brand : Micromax Model Device: Q341 AndrVersion : 5.1 BaseBand CPU: SP7731GEA_HD CompileDate : 07.06.2016 2:25:29 Project Ver : MMX_Q341_RU_SW_V1.1.2_HW_V1.1.0_07062016 Model Ext : Micromax Q341 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Read FullFlash [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : Q341 Model Brand : Micromax Model Device: Q341 AndrVersion : 5.1 BaseBand CPU: SP7731GEA_HD Project Ver : MMX_Q341_RU_SW_V1.1.2_HW_V1.1.0_07062016 Model Ext : Micromax Q341 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.43.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2026 MiB Saved to : C:\InfinityBox\CM2SPD\Flash\SP7731GEA_HD_Q341_5.1_MMX_Q341_RU_SW_V1.1.2_HW_V1.1.0_07062016_Micromax_Q341\ Done! Elapsed: 00:08:39 Reconnect Power/Cable! |
The Following User Says Thank You to Abzal For This Useful Post: |
03-17-2017, 10:50 | #236 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | My phone my28 unlock done Operation : SP Unlock [ v1.24 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Locked! Unlocking ... Unlock Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following User Says Thank You to dyo For This Useful Post: |
03-17-2017, 18:03 | #237 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn Aura Power 4G SC9630 Test Report. Operation : Check/Read Info [ v1.24 ] Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : sp9832a_2h11_4mvoltesea Model Brand : Karbonn Model Device: sp9832a_2h11_volte AndrVersion : 6.0 BaseBand CPU: SP9832A_2H11_VOLTE CompileDate : 1/5/2017 1:51:09 AM Project Ver : UTLAura_Power_4Gv1004_05012017 Model Ext : Karbonn Aura Power 4G ExtraInfo : HWInfo exists!!! This phone have DYNAMIC HW settings!!! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Check/Read Info [ v1.24 ] Code: 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : Platform : MOCORTM_15C_W16.39.3_P3.03_Debug Project : sharkl_cp1 HWInfo : sc9630_modem Phone Security Info : IMEI [1] : 6007384XXXXXXXX IMEI [2] : 6007384XXXXXXXX BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.782 V Done Reconnect Power/Cable! Operation : Read FullFlash [ v1.24 ] Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : sp9832a_2h11_4mvoltesea Model Brand : Karbonn Model Device: sp9832a_2h11_volte AndrVersion : 6.0 BaseBand CPU: SP9832A_2H11_VOLTE Project Ver : UTLAura_Power_4Gv1004_05012017 Model Ext : Karbonn Aura Power 4G [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem_l.bin [Read Ok] : sharkl_cp1.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : l__WPH_arm7.bin [Read Ok] : PM_arm7_sys.bin [Read Ok] : logo_720x1280.bin [Read Ok] : fblogo_720x1280.bin [Read Ok] : wcn_fdl.bin [Read Ok] : AA_MARLIN.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : udc_config.bin [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2648 MiB Saved to : C:\InfinityBox\CM2SPD\Flash\SP9832A_2H11_VOLTE_sp9832a_2h11_volte_6.0_UTLAura_Power_4Gv1004_05012017_Karbonn_Aura_Power_4G\ Done! Elapsed: 00:17:45 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to MyGSM World For This Useful Post: |
03-22-2017, 09:01 | #238 (permalink) |
Member: 2286149 Status: Offline Thanks Meter: 34 | |
03-23-2017, 07:19 | #240 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Set "UK Edition" to "OFF" from Dongle Manager, look here for more help- http://forum.gsmhosting.com/vbb/11420720-post2.html Br. Infinity Box Team. | |
