03-28-2017, 06:45 | #242 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | MAICROMAX Q351_6.0 Read FullFlash DONE CM2 Quote:
The Following User Says Thank You to nahidroman For This Useful Post: |
03-28-2017, 14:27 | #243 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 53
Member: 750751 Status: Offline Thanks Meter: 9 | Pls see this model Telenor , not option for sp unlock. Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 |
03-28-2017, 14:40 | #244 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
But if not working then try this method http://forum.gsmhosting.com/vbb/f296...ution-2193522/ Don't forget to press like button | |
03-28-2017, 15:40 | #245 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
03-28-2017, 23:38 | #246 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2157689 Status: Offline Sonork: thank your Thanks Meter: 1 | Hello help me unlock code frp on itel 1508 via chinesse miracle II 2015 2016 spd with my infinity dongle |
The Following User Says Thank You to yvermars For This Useful Post: |
03-29-2017, 06:16 | #249 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | CM2 NOT support "bin" files. Seems as it file from some "box"? If it PAC - tick PAC and select it. Otherwise - look for PAC or Infinity FW for your model, or alive sample for readout FW. |
03-29-2017, 07:14 | #250 (permalink) |
Member: 750751 Status: Offline Thanks Meter: 9 | Telenor model Here is for this problem full flash: Phone found! [ 47 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 https://www.4shared.com/file/g_FCAM_...LQ32_Engl.html Last edited by galismobil; 03-29-2017 at 07:24. |
The Following User Says Thank You to galismobil For This Useful Post: |
03-30-2017, 08:18 | #251 (permalink) | |
Member: 750751 Status: Offline Thanks Meter: 9 | telenor 2.4inch unlock Quote:
Thanks | |
04-06-2017, 11:45 | #255 (permalink) |
Insane Poster Join Date: Sep 2012 Location: belarus
Member: 1806875 Status: Offline Thanks Meter: 40 | Chinese Miracle II [SPD module] v 1.24 Operation : Read FullFlash [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
The Following User Says Thank You to mirazg For This Useful Post: |
