11-17-2016, 07:49 | #49 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Try with other CPU selections and with ALT LDR/SLDR as well. Br. Infinity Box Support Team. | |
11-17-2016, 07:53 | #51 (permalink) | |
Easiest way to know which cpu inside is to read info in service mode, after you have idea which cpu inside you can proceed with proper cpu selection. Making auto boot will make software more buggy and sluggish, forum will be full of users complaints as it's not safe as well. Br. Infinity Box Support Team. | |
11-17-2016, 08:02 | #53 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
11-17-2016, 08:26 | #54 (permalink) | |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Quote:
SC7710 Yeah it's old but presently or currently having a lot of them in the system so it's absolutely necessary to add them. We are having past at the present so we need to deal with it already added old devices this support. like miracle cs tool piranha. volcano = I have all those tools except cs tool and trust me those tools don't support all sc8810/6820 CPUs. For volcano, it only removes pattern lock instead of full format. For miracle and Piranha, they will warn you of force format and if you are lucky, you have your phone being safely formatted and if not, you have it on hang logo. Their read and write of firmware completely kills phone. Is that what you are advising we should go for? We are looking for unique and perfect features on those CPUs bro. CM have over the past proven to be the best and king of chinese models until date that's why we want them to add because those CPUs are still in the system as said earlier. I believe only CM can work on those CPUs perfectly. | |
11-17-2016, 09:02 | #58 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: pakistan Age: 39
Member: 1789762 Status: Offline Sonork: 1612770 Thanks Meter: 51 | qmobile m95 bro i try but same problem Quote:
==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Failed!!! Selected firmware doesn't match to current HW or EMPTY battery! Flashing terminated! Elapsed: 00:00:03 | |
